I'm considering a wee project to lay a mosaic floor in my porch area which is getting done up soon (I know ... how fancy!).
I have a design I want and can make it out of 4 colours - white, light grey, dark grey, and black.
but, I cant seem to find an obvious source of ~1cm square mosaics tiles. Any ideas / sources ? A lot of the mosaic sheets are 2cm tiles, and I just wont be able to make my design work if they are that size.
tx.
Really?
Googled 1cm mosaic tiles and
https://www.mosaicheaven.com/vitreous-1cm-tiles/81-tile-sheets-from-1-07
Swimming pool mosaics.
jonv... no the other one...
Yeah, I had seen that and have asked them about the suitability of the tiles. But they seem to be the only ones.
Its the 1cm size I seem to be struggling to find. Plenty of mosaic sheets and companies etc.
Lots of 10mm on eBay
but they come on a soluble paper sheet, if you're covering a larger area you use the sheets so the tiles are all properly spaced. If you want smaller sizes, cut down the sheets. Single tiles, just drop the sheets in a bucket of water and the tiles drop off.
A 10cm x 10cm sheet (including spaces) is a 9x9 of tiles, iirc from doing my kitchen
https://hobby-island.co.uk/mini-glass-tiles/quadra-mini-nebula-10mm-iridescent/
Specifications:
<table class="hzw-series-specs" cellspacing="0">
<tbody>
<tr class="hzw-series-specs-row-odd">
<td class="hzw-series-specs-column-one">Tile size:</td>
<td class="hzw-series-specs-column-two">1x1cm (1cm2)</td>
<td class="hzw-series-specs-column-one">Tile thickness:</td>
<td class="hzw-series-specs-column-two">3.5mm thick</td>
</tr>
<td class="hzw-series-specs-column-one">Standard sheet:</td>
<td class="hzw-series-specs-column-two">841 tiles, 30x30cm</td>
<td class="hzw-series-specs-column-one">Sheets per m2:</td>
<td class="hzw-series-specs-column-two">11.1</td>
</tr>
<tr class="hzw-series-specs-row-even">
<td class="hzw-series-specs-column-one">Sheet weight:</td>
<td class="hzw-series-specs-column-two">0.55 kg</td>
<td class="hzw-series-specs-column-one">Box:</td>
<td class="hzw-series-specs-column-two">10 sheets = 0.9 m2</td>
</tr>
</tbody>
</table>
• UVA and Frost Resistant: High Temperature Glass
• Easy to use without cutting
• Cut using wheeled nippers
• Mounted on paper (Soak off in warm water)
• Works well in combination with 2x2 Vitreous Glass
• Suitable for children and less experienced mosaicists
Thanks Jon,
that Hobby island place seems to have what I'm looking for. My google-fu just isn't up to it these days.
