Any suggestions.
Stand and "present"?
Lean back on chair and "chat"?
To how many people? Where and what about?
No visual aids? Sounds like torture for everyone unless you're a good stand-up comedian.
Is this an interview?
Dance.
Yep it's an interview.
Panel of three.
Open with a joke?
Sadly not much of a dancer 🙁
If you do open with a joke...don't do "how do you get a gay man.....".
Stand up straight, don't mumble, eye contact.
Charades. Make them work for it...
By visual aids I presume that is the dreaded PowerPoint?
What is the topic?
Just get interactive and facilitative on them. I am doing a full day of training next week and won't need the laptop...
Whats it about? For an interview I'd be careful about how wacky I'd get. Dependent on business I suppose. Involve the audience with some questions to illustrate points. Closed questions so that they don't take you off piste. No vis aids means no power point but doesn't mean nothing I suspect. I've used an orange effectively (not in a MP type of way) and a pen or phone could be a prop.
10 minute, no visual aid presentation in an interview? Sheesh...
Initial thought then, will be painful for them too.
Obviously, it depends on the brief you've been provided with, so if required knowledge of the industry/profession required, then make sure that's in there.
Be imaginative & engage the interviewees - maybe comment on the fact no visual aids are allowed, so make light of it (they will probably be very sick of interviewing) and invite them to use imagination in a scenario and comment back; make it a two way thing. Make it a discussion, but not overly so though(after all, you are being interviewed, but they will welcome a break from the norm).
It's hard though without knowing more info about what the job is and what your invitation to interview said.
"who'd like to see my impersonation of an elephant?"
7 mins chat, 3 mins summary and questions... simples.
Play them at their own game. Take in some blindfolds, make them wear them whilst you read them a story/poem complete with a box of tricks sound effects.
Unless you're very handsome/sexy/charismatic, you'll have lost them after 20 seconds.
EDIT:
I like that!
Right now you're focussed on what you can't do. Now, you have to think about what you can do.
Your goal is twofold: to be convincing and engaging.
You might try using objects as the focus for your presentation - use relevant tactile aids rather than visual aids to illustrate your points...? I've seen this done very well on a couple of occasions.
Is visual aids worse than cat aids?
Talk for 2 minutes, remove trousers and helicopter d^ck
Usual rule is...
Tell them what you are going to tell them
Tell them it
Tell them what you just told them
And top tip - don't be afraid of silence - the pauses add effect
what is the presentation about ? work out a structure to your resentation. My dad used to say tell them what you want to talk about talk about it , tell them what you have talked about . I saw him do it once it was excrutiating . consider some sort of structure though:-
principle / introduction
material / facts / evidence
argument / opinion
summary / conclusion / proposal
I once had to do a ten minute talk on the role of my department based on a random prop pulled out of a poly bag. I got a 35mm film canister!!
Take a mate to stand in. Dearth Vader suit in the corner.
For no reason other than they will remember you.
Dearth Vader
A somewhat lacking baddie?
pop larkin - Member
Is visual aids worse than cat aids?POSTED 42 MINUTES AGO # REPORT-POST
Nope, it's like Lucozade
Ball gags as well if the audience warrants/deserves them!
Are you allowed to do shadow puppets?
tell them what you're going to tell them (*in summary)
tell them
tell them what you told them (*in summary)
let them ask questions
If you can't communicate what you need to without visual aids then either you've put your presentation together poorly or you struggle with presenting. I accept that some topics need a bit of visual representation, but for most, visual aids just take attention away from the presentation generally and allow people to focus on something other than what you're trying to tell them. Powerpoint is way overused. People automatically assume, oh i'm doing a presentation, better do some slides.
I do loads of presenting and use slides less than 1/3 of the time. My scores on attendee feedback forms are always higher if I've not used powerpoint etc. Focuses the mind on properly communicating a difficult point, rather than just firing the complex stuff up on a slide and trying to make the audience digest it in 60 seconds. And if it's not something that [i]has[/i] to be visualised, wtf are you putting it on a slide for anyway?
I appreciate that visual aids can help strengthen what you're trying to say, but that's only if they're used appropriately/effectively, and most of the time they're not. It's just repetition.
People sticking up powerpoint slides which say roughly the same thing as is coming out of their mouth is one of my pet peeves 🙂
How often do you see the great TED presenters sticking powerpoint up?
The sermon on the mount and "I have a dream" both had to be done when they couldn't get the powerpoint to work and they seem to have gone down quite well.
Just because there is no visual aid you can still write the presentation in the same way. A number of main topics each with 3 or 4 sub topics and a wrap up.
I was once told:
Summarise the situation
Describe the 3 or 4 possible courses of action
Put forward your preferred solution, with reasons.
Watch some pro's and copy them.
[url= http://www.ted.com/talks/ken_robinson_says_schools_kill_creativity.html ]Ken Robinson[/url]
and other great speakers on TED ( might be some related to your job ?)
Take a guitar and do a David Brent style presentation.
Although its not alluded to directly in the gospels its thought Jesus might have used hand puppets in his sermons
"Whats that you say Sootie?.... blessed are the the who?......he says 'Blessed are the Meek' boys and girls"
For me - don't try to learn a 10 min presentation verbatim - at that length if you get derailed at all you'll never pick up again. I tend to have a 30 second ice breaker pretty much down pat and the same for a final conclusion and then in between more freeform.
Have a set of maybe a half a dozen "things" you wish to talk about in an order which best presents and then justifies your thesis and if you find yourself floundering you can just move on to the next "thing". You may well realise what you missed and can slot it in later.
Under each of these headings you can learn a few relevant facts and citations which help make your point but don't overburden your presentation with them, if you don't manage to slot them into the speech you might get them into the Q&A afterwards.
If you do go down this road, try not to be overcome with relief when you get to the conclusion which you know and start rushing it. I gave a politics seminar once to someone I was terrified of and completely lost it in the last 10 seconds...
Marvellous.
I would like to do a powerpoint presentation for that though. A big picture of a globe with an arrow pointing to a little meek man.
Can't believe no one's suggested..
though the helicopter suggestion made me smile
presentation interview are no win - impossible to tell tone required to you actually see the type of people you are presenting to. you can tell how 'serious' they are!
this would be toture for me, been a visual person. I'd use the stlye of the fonts and text to make it visual thing.
Alter size of text and postion and aligment.
good luck with no visual aids
Get a copy of Max Atkinson's book 'Lend Me Your Ears', it's brilliant. Can be had cheaply on Amazon.
Most presentation courses you go on will always say it is about how you say it rather than what you say that makes a good presentation. All presentations fall into two categories: either to persuade or to inform. If they have given you a topic it is probably the latter if it is about yourself then it is the former and the aim of the presentation is to persuade them to employ you.
Assuming the latter, go to someone and ask what they would want to know to be persuaded - they will come up with two or three questions such as what would you bring to the company? and why do you want the job?
So your content is
[b]Introduction (1 min)[/b]
State purpose - persuade you to employ me
What questions you are going to answer i.e. the ones given to you
So for instance:
[b]What would I bring to the company? (4 mins)[/b] (if you have three questions then it is 3 mins for the most important 2 and 2 for the least)
List three or four qualities - no more and illustrate them with examples and anecdotes from your experience, there are other devices you can use but I will keep simple - this is a key bit to getting your point across, they will remember examples and ancedotes much better than just a list.
[b]Why do I want to join the company (4mins)[/b]
Again three or four reasons and put them into a context compared to your present role and make them easy to understand.
[b]Conclusion (1 min)[/b]
Restate aim to persuade you to employ me.
Why me? Restate qualities
Why you? Restate point.
Any questions?
DONE
Bring out your inner Italian when you speak, look at the triangle formed by their eyes and nose and enjoy yourself.
😀 🙂 😕 😐 🙁 😥I'd use the stlye of the fonts and text to make it visual thing.Alter size of text and postion and aligment.
[b]NSFW[/b]
Hope the interview goes better than this one.
Some sound advice in this thread, the only thing I've picked up over the years that doesn't seem to be in and works (for me anyway) to get audience engagement from the off is to open with a question that requires some sort of answer, even if it's only "can you all hear me okay?" or something like that
It's not the subject of the question that matters, it's that the presentees give some sort of answer, that locks them in and makes them feel like they're participating in something, rather than passively viewing / hearing it.
If they don't seem to be responding much, ask "Is English your first language?"
