10 figure grid to G...
[Closed] 10 figure grid to GPX conversion.
I'm trying to find something I can use to convert the above. I found a workaround using "The Hug" by cropping the 10 figures down to 8 but for some reason the GPX co-ords it creates don't show up on my Garmin.
I've got about a hundred of these to convert so it's got to be reasonably quick.
Thanks in advance, D.
Posted : 04/01/2017 11:39 pm
You could do this using GPSBabel.
Probably easiest if you started with grid references in a suitable CSV format. https://www.gpsbabel.org/htmldoc-1.5.3/fmt_unicsv.html
Posted : 05/01/2017 12:08 am
 poly
http://www.movable-type.co.uk/scripts/latlong-os-gridref.html
If you've got gps chords and not being accepted by Garmin are they in right format e.g. N/S +/- or deg,min,sec.dec or deg.dec etc?
Posted : 05/01/2017 12:27 am
Double post
Posted : 05/01/2017 7:10 am
For a waypoint I get: text <gpx> more text <time>2017-01-05T06:00:00Z</time></metadata><wpt lat="12.345678" lon="-1.234567"><ele>-12.345678</ele><time>2017-01-05T05:56:09Z</time><name>007</name><sym>Flag, Blue</sym></wpt></gpx>
and track: text <gpx> more text <trk><name>course</name><trkseg><trkpt lat="54.320100" lon="-2.491550"<ele>139.78</ele<time>2017-01-05T05:54:39Z</time</trkpt></trkseg></trk></gpx>
If that helps!
Posted : 05/01/2017 7:12 am
Thank you all. I'll have a look ๐Ÿ˜€
Posted : 05/01/2017 5:34 pm
