Zero stack turbo wh...
[Closed] Zero stack turbo wheel block
Does such a thing exist? Having swapped from an elite to a wahoo I miss the front wheel block and don't like the feel of the front of the bike wobbling around.
Anyone come up with a hack/diy fix to keep the front end more secure?
Posted : 03/09/2020 12:25 pm
I use a high tech setup of cardboard sandwiching a hardback book, but that's for ~2cm stack! 😆
Posted : 03/09/2020 12:30 pm
I see kinetic do one with variable heights, lowest being 1". Might be able to get away with that.
Posted : 03/09/2020 12:40 pm
Use a normal riser block (if you've already got it) at the front and a bit of wood under the turbo to raise it up and keep the bike level.
Posted : 03/09/2020 2:36 pm
Use a normal riser block (if you’ve already got it) at the front and a bit of wood under the turbo to raise it up and keep the bike level.
Yeah I thought of this, makes it hard to get on off though, its like raising your seat 2".
Posted : 03/09/2020 3:18 pm
Bit of hard board/thin ply with 2 bits of wood screwed either side, with wheel between them? A few thin grip strips underneath if needed.
That would only raise the height a few mm's.
Posted : 03/09/2020 6:43 pm
Yeah I thought of this, makes it hard to get on off though, its like raising your seat 2″.
Not if the piece of wood is large enough to cover the area under the turbo and all the way up to the riser block
Posted : 03/09/2020 10:10 pm
You could lash the bars instead? Or some thin plywood with a couple of wooden blocks would be not quite zero stack, but very small
Posted : 03/09/2020 10:15 pm
