XTR M952 BB compata...
[Closed] XTR M952 BB compatability
6 Users
Hi all,
I have a XTR M952 chainset that I would still like to use, but the BB is no longer an available item.
Can anybody tell me if any currently available BB's are compatable? I seem to remember hearing that a Shimano road octalink BB of some description will fit?
Cheers, Maurice.
Posted : 06/06/2012 8:59 am
I think the Durace one fits, bit the splines are shorter
Posted : 06/06/2012 9:00 am
 gee
113mm or 108mm octalink is the same I think. What length is your current one?
You want either a BB-es70/71 or BB-es50/51 ideally.
GB
Posted : 06/06/2012 9:01 am
 gary
The road octalink spline pattern matches (e.g. dura ace, ultegra, 105). But the lengths available are different so you may need to do some measuring/experimentation to see if they would be viable.
Summary of spline patterns and length options here : [url= http://sheldonbrown.com/gloss_n-o.html#octalink ]http://sheldonbrown.com/gloss_n-o.html#octalink[/url]
The XTR BBs still sometimes pop up on ebay, but less frequently these days and sometimes a bit pricy.
Posted : 06/06/2012 9:07 am
I need a new BB for this crank too. The Sheldon Brown site says that the crank accepts the V1 version of the octalink but the ES 70/71 and 50/51 are V2. However, when I measure the splines on the crank they are 9 mm, which is the length of the V2 splines. Have you used one of these BBs successfully on the XTR?
Posted : 23/09/2012 7:27 pm
BB-ES brackets don't work with 952 cranks. The length of the spline may be ok but the width of the spline is different.
Posted : 23/09/2012 7:44 pm
