need help finding a 36T ring that i can use to adapt M970 XTR chainset to dual ring, any ideas ????
I have tried blackspire but it's only in 104 pcd, i thought XTR was 102 pcd ???
M970?
Standard 104. Blackspire, Middleburn, TA all work fine.
M960?
102mm, you can't fit a 36 unless you get a custom one from someone like Boone titanium.
my mistake M970 104mm pcd was what i meant, need a 36T as i said blackspire produce one but can't seem to find a uk dealer selling them
[url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=35827 ]Huh?[/url]
Out of stock, but most places should do them.
I used a Deore steel one with a Dark Cycles bash ring
Deore steel middle and inner rings on my 970 xtr cranks. The inner needed a few washers to sort the spacing out.
