XT rear mech (shado...
[Closed] XT rear mech (shadow +?) and shifter compatibility
Are the ten speed XT rear mechs all shadow + or are there shadow (no +) mechs too?
I've googled to try and find the difference and all the 10 speeds seem to be shadow plus whereas the 9 speeds were shadow (no +).
Correct?
Does the plus mean with a clutch?
__________________________________________________________________________
2)
Why are 10 speed RH shifters out of stock in so many places?
I need a single (not pair) shifter, 10 speed. Bar mount.
Is there a Shimano production / delivery problem?
Are SRAM and Shimano 10 speed shifters and mechs compatible?
Thanks
Posted : 26/10/2014 5:43 am
edit: do I need bar mount shifters? Are there others I can use?
I have BR M785 (XT) brakes. Is this enough info for you gurus to tell me if I have I spec A, B, whateverthehelltheyrecalled*?
God all these specifications make my brain hurt.
Posted : 26/10/2014 6:09 am
 cp
The plus does mean clutch.
10 speed in both shadow and shadow+
9 speed is shadow (and old school) with no shadow plus.
Everyman and his dog is going 1x10. I suspect demand exceeds supply.
If you buy I spec b compatible shifters, they will definitely attach to your brakes as it is backwards compatible should your brakes happen to be ispec a.
Posted : 26/10/2014 8:39 am
Saint shifters available in bar-mount flavour on CRC
Posted : 26/10/2014 8:50 am
cp. So is 10 speed shadow without a clutch?
tmb. I'm too tight to buy Saint! They have XTR too!
Posted : 26/10/2014 4:29 pm
10 speed shadow doesnt have clutch
Posted : 26/10/2014 4:30 pm
XT RH shifter in stock at tweeks.
http://www.tweekscycles.com/components/mtb-gear-shifters/shimano-sl-m780-xt-dyna-sys-10-speed-rapidfire-shifters.
Got mine from here a bit ago and its full retail boxed too.
Posted : 26/10/2014 8:28 pm
XT Shadow rear derailleur(no clutch)
[url= http://www.tweekscycles.com/components/mtb-rear-derailleurs/shimano-deore-xt-rear-derailleur-m781-shadow ]LINKY[/url]
XT Shadow Plus rear derailleur(with clutch ,see the little grey lever)
[url= http://www.tweekscycles.com/components/mtb-rear-derailleurs/shimano-deore-xt-rear-derailleur-m786-shadow- ]LINKY[/url]
Posted : 26/10/2014 8:32 pm
Tweeks have Saint, SLX, Zee, XT and XTR right hand only shifters in stock.
as above...shadow+ is clutched and shadow is non-clutched
just remember that 10sp is NOT compatible with 7.8 or 9sp.
Posted : 27/10/2014 4:26 pm
Saint is a bit pricier but it's also the best shifter Shimano have ever made- basically they stole all the good bits about SRAM 9-speed, bolt-action feel with Shimano quality. Mint.
<edit- though to be fair if you actually like how normal shimano shifters feel, then you might hate it. But you're weird>
Posted : 27/10/2014 5:50 pm
My 10spd XT kit doesn't shift nearly as nice as the old 9spd XT imho/ime
Posted : 27/10/2014 8:19 pm
I just fitted xt shadow + mech and saint shifter...all i can say is wow what a great combo..i came from a 9 spd xt rear ams xtr shifter amd the new combo bears it easily. .like hot knife thru butter
Posted : 27/10/2014 9:13 pm
