X9 Jockey Wheels - ...
[Closed] X9 Jockey Wheels - How much!! (Any alternative to SRAM)
Need new jockey wheels for my 2009 SRAM X9 Mech.
Cant believe the price. Cheapest I can find is £28.
http://www.chainreactioncycles.com/Models.aspx?ModelID=6520
The earlier and later models seem cheaper, typical.
Is there an alterntive aftermarket product.
Posted : 29/12/2011 12:13 pm
I used to just swap over the bearing instead (cost around £5-£7)
SKF bearings I think is was a 6801-2RS
Posted : 29/12/2011 12:31 pm
Thats SRAM aftermarket prices for you... 😯
You can pick the seals off the bearings, clean them and regrease them, this is easy to do and revived mine after they'd seized solid.
Posted : 29/12/2011 12:33 pm
Are these not the ones you want?
http://www.chainreactioncycles.com/Models.aspx?ModelID=7316
Posted : 29/12/2011 12:34 pm
BBB sale after market ones too.
Posted : 29/12/2011 12:35 pm
This, then sell it and swap to Shimano instead.
Posted : 29/12/2011 12:38 pm
Haha, GENIUS! Those ones dan1980 linked to even have a special offset hole system so you can't use aftermarket options.
I'd love to hear SRAM's justification for some of the prices they charge, I've just found out my X9 rear mech retails at £100! Its already failed/bent more than the £40 LX mech I'd had for six years previously
*removes stuck record etc etc*
Edit: Cha****ng, you're preaching to the converted, I'll never be buying SRAM again, for all the reassuring clunky shifting in the world...
Posted : 29/12/2011 12:39 pm
If you're thing to replace them then give the kcnc alloy ones a try.
Posted : 29/12/2011 12:40 pm
BBB for me also 🙂
Posted : 29/12/2011 12:41 pm
Thanks for all the replies.
It's the wheel itself that is worn, so unfortunately bearing change/clean isn't going to solve the problem.
Couldn't see any BBB ones that are compatible. However found an old X7 in the garage and those fit. So sorted for now.
When the mech finally dies will definitely be considering the move back to Shimano, after 8 years with SRAM, as finding that it just doesnt last and the new X9 on my FS has so much stiction it's virtually unusable. O and the jockey wheels in the 2010 are different again and have a different size bolt so can't even swap those across.
Posted : 29/12/2011 4:00 pm
Tacx jockey wheels,[url= http://www.wiggle.co.uk/tacx-jockey-wheels-with-stainless-steel-bearings/ ]Decathlon sell these for £8!![/url]Bargain.
Posted : 29/12/2011 4:02 pm
I use the x7 or x5 ones which are pretty much identical
Posted : 29/12/2011 4:09 pm
Think youself lucky you wore the jockey wheels out, i had a X9 rear mech and the pivots became so loose it was unuseable before the jockey wheels where even a quarter worn 😥
Posted : 29/12/2011 4:49 pm
I've always been dissappointed in the cost of things like jockey wheels. BBB worked for me though. cost a tenner or so - wheels seem much more hard wearing than the SRAM versions too.
Posted : 29/12/2011 4:52 pm
