would you be able t...
[Closed] would you be able to fit 650 B wheels on a normal 26er frame and forks ?
just a thought as I have a hardtail with fox 120 forks and wondered if this was possible ? and also to save money !
cheers
Posted : 26/04/2012 7:32 pm
X-Fusion claim their 26" forks are OK for 650b.
Check the rolling radius and you may be OK with your Foxes.
PaulD
Posted : 26/04/2012 7:34 pm
.75" extra...I doubt it unless you use narrow tires, which would be a bit pointless.
Posted : 26/04/2012 7:36 pm
its almost too good to be true really ...I think fox are bringing out a 650b fork ?
Posted : 26/04/2012 7:38 pm
Check the rolling radius of the wheel and tyre combo....If you can run 26x2.5" you may be able to run 650b x 2.1" or possibly 2.25"
PaulD
Posted : 26/04/2012 7:40 pm
oh I see how it works now ..well so stans flows can take that I think, so should be ok ish
Posted : 26/04/2012 7:45 pm
What frame have you got? All Fox forks work with 650b, not sure with what tyres though. Have a look on the 650b thread on MTBR and the 650B Palace website...I think both have lists of what frames and forks are compatible.
Posted : 26/04/2012 7:48 pm
my frame is a 2012 ns surge so it has plenty of room I think
Posted : 26/04/2012 7:50 pm
thanks for the info guys ....big help ๐Ÿ™‚
Posted : 26/04/2012 7:51 pm
There's a big ol' list of compatible frames on mtbr. It seems forks are the real problem, but not for much longer.
I've got to say, I'd be tempted if I had the funds to change fork as well as wheels.
[url= http://forums.mtbr.com/650b/my-list-650b-compatible-26ers-376656-post4013606.html ]Here it is[/url]
Posted : 26/04/2012 8:14 pm
It seems that fox forks are ok so that would save money too !
Posted : 26/04/2012 8:33 pm
 gee
Your forks will fit in terms of the arch. You also mut check your specific wheel/tyre/fork combination fits under the crown at full travel by letting all the air out and leaning on the fork.
If you have a hardtail, it's just a matter of trying the wheel in the frame.
GB
Posted : 26/04/2012 8:45 pm
Richie - you need full suspension, not more wheels!!!
Happy Birthday though ๐Ÿ˜€
Posted : 26/04/2012 10:13 pm
cheers clucas ....see you out on the trails ๐Ÿ™‚
Posted : 26/04/2012 10:22 pm
