Just wondering what arrangement are others using on their Mojo SLs?
I have XX cranks with a Hope BB and after not being able to shift into the big ring with 2 x 2.5 spacers on the drivetrain side I've moved them this morning so that I have 1 x 2.5 mm spcaer on either side. Only downside of this is that the chainrings are much closer to the chainstays and can imagine chain suck being an issue. It was all working fine until I removed the BB to replace the bearings and then must have changed the spacers, though I thought i hadn't. Flip side of the coin is that running 2 x 2.5 spacers on the drivetrain side is the correct way to go and I have another problem.
So back to the original question, which configuration of BB spacers are riders running on their Mojos?
All sorted, re-did exactly the same as las tight and now shifting perfectly - WTF!
