Whyte 901 replaceme...
[Closed] Whyte 901 replacement frame
13 Users
After cracking the chainstay on my secondhand Whyte 901 frame, I'm looking for a frame to replace it as the warranty does not cover secondhand bikes :(.  Whyte don't sell frames on their own, so looking for an alternative that will have 148mm rear spacing and will fit a 130mm fork.
Have an eye on the Cotic Soul frame, as it seems to fit the bill, but pricey.
So looking/asking to see if there is anything else.
Posted : 04/07/2018 10:14 am
Commencal Meta HT frame (2018 model less than 400 bucks)?
You might have to contact Commencal and ask if 130 mm is "enough" for the Meta.
Posted : 04/07/2018 1:37 pm
Bird Zero?
Posted : 04/07/2018 1:39 pm
Commencal has been emailed, but looks like it's for a 140-160mm.
Liking the Bird Zero, but sizes start from medium.  I'll need a small.
Posted : 04/07/2018 10:03 pm
It might be worth ringing Bird to ask about sizing to check. Most of their frames have a low standover height and are deliberately longer than most. But then they have quite a steep seat tube angle so the stretch to the bars isn’t what you think.
Posted : 05/07/2018 7:24 am
Think the Zero TR comes in a small
Posted : 05/07/2018 7:40 am
Commencal has been emailed, but looks like it’s for a 140-160mm.
The bike geo is very "slack" - wouldn't be worried about the head angle getting a bit steeper when using a 130 mm fork.
More critical: the BB drop. Think the Meta HT has quite a low BB. Not to suffer pedal strikes too often you might have to run the 130 mm fork with a little "less sag" then.
And then it's up to the fork: is your fork fun also with less sag?
If you get the Meta HT frame working: fun bike! Frame pricing is very good (some frames are always "in sale" at Commencal...).
Posted : 05/07/2018 10:08 am
Ah, just noticed, the Bird Zero AM Boost is 150 or 160mm fork, I need 130mm.
And the Zero TR is not boost.
But the Orange Clockwork 137 seems to fit the bill:
https://www.orangebikes.co.uk/bikes/clockwork-137-frame/2018
Posted : 05/07/2018 10:29 am
Depending how old the frame is, it might be worth contacting Whyte.
I know is SH, I've heard only good things.
Posted : 05/07/2018 10:53 am
The frame is still under 2 years old, but Whyte are not replacing it as it's secondhand.
They where going to try and source a frame for cost price.
I have heard nothing.
Posted : 05/07/2018 11:33 am
What model of forks? Can they not be extended, to more suit the suggestions?
Posted : 05/07/2018 5:48 pm
http://www.bikescene.co.uk/ORANGECLEARANCE-122.html
Posted : 05/07/2018 6:19 pm
Sonder Transmitter. Boost backend and 130mm fork from memory. It's designed for 27.5 plus but has a highish BB, so running some big normal 27.5 tyres could be spot on.
Posted : 05/07/2018 6:56 pm
Airdrop bitmap? That takes a 140mm fork, with a boost back end.
Posted : 05/07/2018 9:08 pm
Thanks 1timmy1, Sonder Transmitter it is.
Nice price as well 🙂
Posted : 09/07/2018 1:31 pm
Orange Clockwork 137. 148 rear end, for 130mm forks and cheaper than a Soul.
Posted : 09/07/2018 2:40 pm
Nukeproof scout 275?
Posted : 09/07/2018 8:43 pm
