Which Bash Guard
[Closed] Which Bash Guard
Anyone got a good recommendation for a light, thin, cheap, ally bash guard.
104bcd
its replacing a thoroughly smashed shimano plastic jobby - will i also need need new chain ring bolts?
Posted : 08/04/2016 10:36 am
[url= http://www.chainreactioncycles.com/hope-lightweight-bash-guard/rp-prod80485 ]Hope[/url]
Posted : 08/04/2016 10:40 am
Have you got ISCG tabs? I'd mount one there if you can, the protection is just as good but you can't pack mud into it like a crank mounted one (as happened to me last weekend before causing odd chain dropping issues )
Light, strong, cheap.......pick two. 😀
Posted : 08/04/2016 10:41 am
I've had a few BBG bash rings in different sizes over the years and they've served me well; quite possibly the closest you'll get to strong, light - and cheap.
http://shop.bbgbashguard.com/products
In fact I've got a used black 104bcd 36t ring you can have for a fiver.
Posted : 08/04/2016 10:53 am
in that case, light and cheap
legend - how does a bash guard mount to ISCG? Not that i can remember if the frame does or not.....
Posted : 08/04/2016 11:03 am
If you have ISCG mounts then 77designz to a crash plate - I've just installed one and it looks well up to the job whilst being discrete.. http://77designz.com/product/crash-plate-34t
Posted : 08/04/2016 11:09 am
its ok, CRC explained it to me 🙂
I have a blackspire chain device/bash guard mounted on my bikes instead of the big ring - have to say I am not sure you'd think it was light or indeed cheap - depends on your budget and perceptions
Posted : 08/04/2016 11:15 am
I've got a Superstar one on my Spitfire. There is a mud issue when it's particularly sticky but as Keith @ Banshee pointed out, a bash ring is less likely to hang up when it hits than a taco because the ring can rotate, and a ring mounted on the cranks is easier on the frame than a taco on the ISCG tabs. Ring also helps keep the chain on.
Posted : 08/04/2016 11:23 am
Shimano Saint CD50?
Posted : 08/04/2016 11:30 am
the superstar composite one is cheap (£15)
Posted : 08/04/2016 11:31 am
^sorry did i say cheap, i might have meant disposable.
Posted : 25/04/2016 12:34 pm
