What headset press?
[Closed] What headset press?
[#10906945]
Sub £100
capable of multiple cup sizes
Used to have Cyclus one which was solid but not a clue where it went!!
Posted : 10/11/2019 8:32 pm
I got a Unior one in a sale a while ago. It's great and (a bit) under 100 quid RRP
Posted : 10/11/2019 8:34 pm
 LAT
Hammer and a golf ball. Perfect. You probably have a hammer already. If you hang about in the bushes on a golf course a golf ball is sure to come your way soon enough.
Posted : 10/11/2019 9:19 pm
Sub £100
Pardon?
Iv'e got one you can have for £25 but I can't find any photo's.
Posted : 10/11/2019 9:23 pm
Make / model please?
Posted : 10/11/2019 9:35 pm
Long bolt. Big nut. 2 metal washers. 2 leftover bits of wood from the hole saw. Two large washers from the plumbing odds and sods box. Job jobbed.
Posted : 10/11/2019 10:03 pm
15 years of fitting headsets and I’ve been using a hammer and a couple of bits of wood.
No problems 😀
Posted : 10/11/2019 11:04 pm
Rubber mallet for me. I do own a headset press but the hammer works with all headset standards, and won't ever rotate the cups (if you're doing an angleset or you want to line up logos)
Sure, you can screw up and put it in really squint... But you can screw up with a headset press too, if you're that useless
Posted : 10/11/2019 11:18 pm
+1 for the golf ball
Posted : 10/11/2019 11:35 pm
Studded bar washers and wood for me
Posted : 10/11/2019 11:39 pm
After years of doing it with a hammer and bits of wood, without any problem other than performance anxiety, a friend of mine assured me he would do a great job using a vice.
He got it partly rotated, and it only went in straight because, after watching him mess around getting in crooked, I insisted he start it off with a hammer and a block of wood.
EDIT: my most recent bike frame had integrated (semi?) headset cups. Game changer!
Posted : 10/11/2019 11:53 pm
I fitted an njs diraace threaded headset with a hammer for a mate.
I say fitted, what I actually did was crack the ****er.
Headset press for me. Cyclos one works grands and has bearing races so not sure how it could rotate anything?
Posted : 11/11/2019 7:05 am
I don't have one but do have some of the normal bearing presses which are really nice. I'll probably get one next time I need one.
https://www.bearingprotools.com/products/headset-cup-press
Posted : 11/11/2019 8:48 am
Top tip: Freeze the cups overnight. Warm the frame too if you can.
Posted : 11/11/2019 8:51 am
I've spent years fitting them with hammers, threaded bar, washers and sockets.
Last year bought a headset press, and yes, it achieves the same result, but it's so much nicer, and feels a lot more mechanically sympathetic, and removes the worry of accidentally wedding something very expensive. Plus works a treat on bottom brackets. (Which obviously you can also do using the above methods)
I bought the 40 quid X Tools one. It's grand.
Posted : 11/11/2019 8:54 am
