Using an integrated...
[Closed] Using an integrated headset with headset reducers....
2 Users
ok, so i have a tapered 1 1/8th > 1 1/4 headtube on my giant, and i want to run a standard straight steerer fork.
i have brought a reducer shim for the lower end of the headtube, but just thought...the bearings wont fit into the shim! Any way around this? or am i screwed?!!
any help gratefully recieved!
Posted : 14/10/2014 12:35 pm
Standard taper is 1 1/8" top and 1.5" at the bottom, not 1 1/4. If the Giant is 1 1/4 then that'll be your problem.
Posted : 14/10/2014 12:37 pm
yep it is 1 1/4 at the bottom, it's giant PITA system!
Posted : 14/10/2014 12:41 pm
Out of interest, what fork is in there at the moment?
Posted : 14/10/2014 12:48 pm
standard 2013 tcx 2 tapered aluminium fork....just quite fancy a carbon fork
Posted : 14/10/2014 12:52 pm
Ah, road bike. I did wonder.
You're going to be a bit stuck I expect unless you can get someone to machine a shim for you (it's a very simple design obviously)
Posted : 14/10/2014 12:53 pm
yeah i was hoping to just get a crown race reducer, but its a no-go it seems!
Posted : 14/10/2014 12:55 pm
aye, thats what i have on order, just cant see me getting an integrated headset to work.....unless i try a standard headset?
jeez, its frying my brain
Posted : 14/10/2014 12:59 pm
Time for a new frame 🙂
Posted : 14/10/2014 1:00 pm
