tubeless help pleas...
[Closed] tubeless help please chunky monkey front & Smorg rear
[#5348548]
I'm thinking of getting a full Stans kit from the Lbs ( £60 ). Thing is my tyres are quite floppy on the rims and I only have a track-pump. Will it work or do I need Co2....
Any tips?
Posted : 19/07/2013 10:52 pm
Stans flowEX rim, SS tape, valve and a chunky monkey filled with Stans no tube solution went up Ok with just a cheapo Blackburn track Pump.
Put a tube in first and inflate to get the bead seated and tape nicely pressed home, deflate, remove tube breaking only one bead seal, insert valve, sealant, pop tyre back on and inflate. Slosh about a bit. Sorted
Posted : 19/07/2013 10:59 pm
As above.. plus a bit of washing-up liquid on the bead to help too..
Posted : 19/07/2013 11:02 pm
And the rims are ?
Posted : 19/07/2013 11:10 pm
Chunky Monkey was so easy to get up tubeless on my roval rims. Do it properly with washing up liquid though but a track pump does the job fine.
Posted : 19/07/2013 11:12 pm
Rims are Alex supra 20.
Do I leave the original rim-tape on?
Posted : 20/07/2013 12:41 am
No, take the original tape off. Watch the vids on the Stans site
Posted : 20/07/2013 8:38 am
Have decided to try it ghetto style first...anything I should know? I take it I leave the original tape on now.?
Posted : 20/07/2013 5:09 pm
if track pump dosen't work try the ghetto tubeless inflator. works amazingly well!
Posted : 20/07/2013 5:12 pm
Is that the coke bottle forced air thingymajig?
Posted : 20/07/2013 5:27 pm
Yes, theres a thread on here about it
Posted : 20/07/2013 9:34 pm
Thanks for all the tips peeps. Don't know what I was worried about...they went up a doddle.
Anyone reading this thread for the same reason, the only thing I'd add is to take your time cutting the tube down the middle if there's no seam to follow.
Posted : 20/07/2013 9:44 pm
