Tubeless help
[Closed] Tubeless help
3 Users
I have stans flow ex fitted and was wondering what I would need to go tubeless. Is it just new valves or does it also need a full stans kit?
Posted : 28/03/2014 8:48 pm
My Flow ex's are finished with three runs of insulation tape, valves cut from tubes and some sealant from eBay. Done in minutes and beads pop within couple of hits from track pump. Easy.
Posted : 28/03/2014 9:41 pm
I have flow EX's, the best option imo is to use the superstar 29mm rim tape and valves as the 25mm stans tape isn't wide enough to cover the small holes in the bead bench. Tape, valves and stans sealant is all you need if your tyres are suitable.
Posted : 28/03/2014 10:27 pm
