Having issues with pinch-flats on the hack. Anyone tried to run 700c touring tyres tubeless (with eg. a NoTubes rim strip & sealant)? If so, what tyres, and how well did it work?
Andy
Only used proper tubeless tyres - what pressures are you running?
6 Bar rings a bell; I appreciate this would be a bit much for tubeless. Problem is that I don't think anyone makes proper tubeless 700x35c slicks...
I think you are right. Flats at 90psi on a 700 x 35 seems odd though, you doing a lot of rough paths?
No - it's a bit odd. Got home from a 15 mile round trip (on what passes for smooth tarmac in Pennine Lancashire), sat down in kitchen & heard loud & ominous hissing from garage. I suspect this is due to cack-handed tube installation as much as anything else (run the MTB tubeless) but haven't had a chance to take the tyre off to investigate. No obvious surface damage though.
Wondering whether I might be able to solve the problem by not having tubes.
v. unlikely to be a pinch flat.
you need proper tubeless tyres for road work, and the Hutchinson Intensive in 25mm is the widest that I know of.
Having said that, I ran a regular 28mm Conti GP4Season as tubeless (ghetto) for a few days but the sidewalls were leaky, even with loads of sealant.
Just check your rimtape and current tyres for flints/debris. Decent tyres are pretty bullet proof - I've not had a puncture on my 28mm GP4s on my commuter for well over two years.
No. Hole by the valve, on the rim side. This is about the third tube I've had go there. At a loss to explain this one. Only possibility I can think of is that it's a spoke head peeping through (it's a sh!tty single wall rim) since I changed the old perished rubber rim strip for a fabric Ritchey one, but the hole doesn't seem to be near any of the spoke heads.
If it does it again, I'm off down the LBS to see about re-rimming the wheel.
Andy
If you're getting punctures rim side, its nothing to with the tyre, its the rimtape/rim
Get some velox rim cloth, and check the rim for burrs
