Just recently got myself the above BB.
Just a quickie, when I installed it I noticed on the non drive side the bearing case (if that makes sense) isn't flush with the bearing... Is this normal?? If not help!!!!! Haha 🙂
All help will be appreciated
Frazer
Bump
Do you mean the outside of the bearing? The face plate sort of thing? From memory; I don't think they are flush, as i remember thinking the same thing myself.
The face plate being the bit between the crank arm ad bearing??
As the drive side is flush with the bearing totally encased
I'll have a look for you tonight, and post up. But I seem to recall fitting the cranks and thinking it didn't look quite right. They've been fine though in a weighs-the-same-as-the-rest-of-the-bike type of way 😉
If you can post a photo up that will help a lot. Cheers
If you mail me (address in profile) I'll sort you a piccy out this evening. I'll have to scrape the copious amounts of mud off them first 😀
Emailed you. Hope it got there. If not
Frazerb14@hotmail.com
