The great Shimano m...
[Closed] The great Shimano mineral oil drought of 2021. When/where can i get some?
Got a couple of brakesets that need their fluid replacing. Was considering buying a 1l tub, for future changes, none available anywhere. Same with the smaller bottles.
Some eBay sellers do the smaller quantities but I dont want to, unwittingly, buy any of that Ali express stuff.
Assuming I can't source any Shimano fluid, what else is out there? Cyclo is about all I can seem to find.
Posted : 25/03/2021 3:33 pm
I've used Lhm suspension fluid before.
Posted : 25/03/2021 3:34 pm
Some chatter on here including LHM, some blue stuff and piss - https://singletrackworld.com/forum/topic/why-is-shimano-mineral-oil-now-suddenly-gone-3-or-4-times-as-expensive/
Posted : 25/03/2021 3:45 pm
Its the same stuff as Citroen LHM suspension fluid. Get it in huge bottles in Halfords. Exactly the same stuff.
https://www.halfords.com/motoring/engine-oils-and-fluids/brake-clutch-fluid/comma-l.h.m.-plus-1l-124424.html
Bit cheaper at places like GSF or try your local motoring factors.
Posted : 25/03/2021 3:46 pm
Citroen LHM
Yep, should be under a tenner for a Litre...
Posted : 25/03/2021 3:53 pm
I've used LHM before, its not exactly the same but I've not had any issues. For the cost I prefer to use Shimano but that's not much help if you can't buy it. Halfords do an own brand (bikehut) small bottle of mineral brake fluid
Posted : 25/03/2021 4:10 pm
Why are shops that sell car parts called 'motor factors'?
Posted : 25/03/2021 4:14 pm
Why are shops that sell car parts called ‘motor factors’?
I said exactly the same words to myself when I typed it in originally!!
Posted : 25/03/2021 4:15 pm
LHM is defo more viscous than Shimano Fluid.
I wouldn't use it if I had the choice as more patience is required to get a good bleed.
Posted : 25/03/2021 4:18 pm
Juice Lubes Mineral Oil
Posted : 25/03/2021 4:30 pm
 tomd
I got a bottle of the cyclo stuff recently, filled 2 sets of brakes with it and have yet to die. Same issue as you, couldn't get the Shimano stuff. The cyclo stuff is £££ per ml though, even if the bottle is quite cheap. Will try the LHM stuff next time I think.
Posted : 25/03/2021 4:58 pm
Could you mix LHM with normal Shimano? And would it help with the viscosity to make it easier to bleed? I have some Shimano MO but not really enough.
Posted : 25/03/2021 5:24 pm
a mate of mine bought crypto, i bought shimano mineral oil.
whose laughing now eh?
Posted : 25/03/2021 5:25 pm
Motorex who make some lubes for Shimano also make Fluid 75 which is I am sure totally different and will void your warranty and cause your world to implode, but also works fine.
Posted : 25/03/2021 5:53 pm
I’ve just bought some shimano mineral oil on eBay, was £7 for 100ml but it’s out there..
Posted : 25/03/2021 5:55 pm
I've got about 1ltr of the stuff sat on in the shelf in my garage an no Shimano brakes to use it with. Am I sat on a Gold Mine?
Posted : 25/03/2021 5:58 pm
Factor: A doer or transactor of business for another person
A person or organization that buys and sells goods for others, on commission
Because of the huge amount of stock items they might need parts companies had stuff they stocked but only paid for when they sold it, acting more as sales men on commission.
Posted : 25/03/2021 6:15 pm
I'm sure I've seen someone using baby oil before?
I've got a bottle of LHM, it's much closer in viscosity to suspension or engine oil than brake fluid. It works, but the brakes feel different and it was a bit of a PITA.
Shortages aside, the Shimano stuff is normally £16/big bottle, it's not worth the agro of trying other stuff. The motorex stuff sounds like a good bet though.
Posted : 25/03/2021 6:20 pm
Would diesel work?
I'm wondering if you could get a perfect bleed in them the same way trials riders bleed DOT fluid brakes with water in a bucket? Just a bit messier to clean off.
Posted : 25/03/2021 6:22 pm
I've used cooking oil from a french refuge when in the alps before and I pulled a shimano hose off in a crash. Luckily had goodridge fittings so was just a case of shortening the snapped hose, but I made sure to fully flush out any of the blue stuff (magura I think) that was already in the system and rode like that for about a year no problem. Did end up scrapping the brakes due to piston leak but the other end that was running shimano genuine stuff died around the same time too!
Posted : 25/03/2021 6:27 pm
Thinking about it, 2T oil must be a similar viscosity? and I presume it's designed not to boil so that it coats the crank and cylinder?
Posted : 25/03/2021 6:45 pm
 StuE
I've been using the LHM stuff since Shimano started making disc brakes and have never had a problem with it
Posted : 25/03/2021 7:58 pm
Is this the stuff?
1Ltr Mineral Oil on Amazon
EDIT - just noticed the delivery charge 😮
Posted : 25/03/2021 8:15 pm
Bought 100ml of the eBay stuff which, they claim, is genuine. Repackaged from bulk purchase, allegedly.
It's the right colour, anyway.
Posted : 25/03/2021 10:18 pm
Morgan Blue Hydraulic Mineral Oil works superbly with Shimano brakes IME.
It's available for about £30/litre - how does that compare to the Shimano stuff or other alternatives?
Posted : 26/03/2021 10:19 am
b230ftw
It's not the same, just compare them side by side. I had problems with the pistons not retracting after using LHM.
Posted : 26/03/2021 10:36 am
Would I have to drain all my shimano mineral oil before using a different type of oil ? Or can I just add it to what's already there
Posted : 26/03/2021 10:50 am
LHM will work, bit it isn't the same. Its more viscous. I used it for a while, but my brake were definitely more sluggish. Especially the levers.
Posted : 26/03/2021 1:12 pm
Allegedly Johnson's Baby Oil is mineral oil and pretty low viscosity, people claim to have bled brakes with it.
A quick google suggests it only a couple of quid for 500ml.
Now my search history has 'baby oil' in it...
Posted : 26/03/2021 1:48 pm
As if it didn't already....
Posted : 26/03/2021 2:04 pm
I have used LHM from Halfords with no ill effects. I also once bled a brake halfway down the KLL side of the Devil's Staircase with water sucked up from a stream and dribbled into the reservoir. (Not my bike. Not my worn pads. Not my basic error popping the piston while changing pads. I just happened to be the mug that had to remedy the situation.) That worked all the way down to KLL via the Ciaran Path. I replaced it with mineral oil as soon as we got home.
Posted : 26/03/2021 2:37 pm
Other recommended fluids can be read about here.
Pentosin CHF7.1 can be bought from EuroCarParts
Posted : 26/03/2021 2:43 pm
I recently got some from ze Germans (R2bike) but they are currently out of stock.
Posted : 26/03/2021 2:47 pm
 Alex
Magura Royal Blood in my new Shimano brakes on the Mojo4. No issue with bleed or performance. Only 4 rides tho.
Posted : 26/03/2021 3:17 pm
I've also used the LMH stuff from Halfords and found while it worked OK it was more viscous than the Shimano stuff so getting a really good bleed was harder and the lever feel was different; little bit slow and dead feeling. But when you squeezed the lever the bike stopped, so it was OK but not great.
I've since stopped using it and I have used Epic Bleed's Shimano compatible mineral oil and the Bikehut mineral oil brake fluid (different to the LMH stuff) in the past and that had a much better feel and as far as I can tell gives same performance as the Shimano stuff.
https://epicbleedsolutions.com/collections/fluids/products/shimano-mineral-oil?variant=30362383319114
https://www.halfords.com/cycling/bike-parts/bike-brakes/bikehut-mineral-oil-brake-fluid---125ml-169049.html
Epic Bleed solution do 3 types of mineral oil (Shimano, Magura, Generic) and the description on all of them is that they are compatible with Shimano, Magura, Formula. So I'm guessing that all those brand's brake fluids are cross compatible?
Posted : 26/03/2021 4:12 pm
If you're in the UK I can send you some genuine shimano mineral oil poured from a litre bottle into a thoroughly cleaned and dried out little 200ml bottle, just cover the postage.
Posted : 27/03/2021 10:28 am
I don’t have any Shimano brakes any more but simply used to use ISO10 hydraulic oil. I always have 20-25 litres of this in stock as we use it in vintage vehicle brakes, machinery etc. The problem with baby oil and the like I’m guessing is it won’t have the required additives to prevent foaming, overheating etc but will have perfumes. Whatever pressure and heat is encountered in mtb brakes, I can’t imagine it being more than would be found in 10 ton vehicles...
Posted : 27/03/2021 11:28 am
Just to add - just checked the viscosity of iso10 and it looks to be about half as viscous as LHM so may be better as a short term option.
Posted : 27/03/2021 11:37 am
 Tim
I've got loads in my shed. Maybe I should start bottling it for eBay 😜
Posted : 27/03/2021 12:05 pm
One advantage of mineral oil over brake fluid is that it can be stored indefinitely, unlike brake fluid, which collects water. I think the primary problem with this is that it will presumably reduce the boiling point. Having said that I’ve used plenty of fairly old brake fluid in the past without obvious issues.
Posted : 27/03/2021 2:38 pm
I've been reading a fair bit about Putoline HPX R 2.5W:
https://www.ebay.co.uk/itm/264728643488?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=264728643488&targetid=1139674280107&device=c&mktype=pla&googleloc=9046362&poi=9046363&campaignid=12126112989&mkgroupid=118099230938&rlsatarget=aud-629407026865:pla-1139674280107&abcId=9300482&merchantid=115124607&gclid=CjwKCAjwr_uCBhAFEiwAX8YJgR4e3AG-jGJLnsM-AUYGr-_b7qPRMjMXgpVCDLJtyxqV9MxqKmHqOhoCSIEQAvD_BwE
It's all the rage in Germany, apparently, and solves the wandering bite point some people experience. It's also meant to be better at lower temperatures.
In fact, I've just bought a litre during the process of typing this, as it inspired me to give it a go. It does void warranty though. So, fortune favours the brave, and all that!
Posted : 27/03/2021 2:48 pm
First Google search suggested putoline in a reverb also as it used 2.5w mineral oil... Does that mean reverb oil works in Shimano brakes?
My big Shimano bottle is all but empty and I've got a few reverb bottles kicking about and thankfully no reverbs to use it in.
Posted : 27/03/2021 4:37 pm
I’m sure Seth on YouTube ran baby oil in his for like 12 months to see how it went!!
Posted : 27/03/2021 7:45 pm
baby oil is fine, but it doesnt seem to work on reverb (although that could well be a different fault)
Posted : 27/03/2021 8:22 pm
Putoline sell a min oil... I use it.
Posted : 27/03/2021 9:20 pm
 Olly
i use Halfrauds LMH, ive been using the same bottle for years across a whole raft of brakes, not had any specific issues.
I think the lever feels slower, compared to a box fresh servo wave unit, but not enough to make me worry.
you certainly wouldnt notice out and about.
Posted : 29/03/2021 9:34 am
Having ended up with numerous bottles of Reverb oil that's what I've been using in my Shimano brakes for a few years - works fine.
Posted : 29/03/2021 10:18 am
 tomd
Anyone tried low viscosity industrial hydraulic mineral oil like Castrol Hyspin AWS? If it's good enough for critical hydraulic systems why not some brakes?
Viscosity is half LHM fluid, can be had for £10/l on ebay.
This stuff:
https://www.cromwell.co.uk/shop/lubricants-and-chemicals/oils/208ltr-hyspin-aws-10/p/CST7403466S?gclid=CjwKCAjw3pWDBhB3EiwAV1c5rB3PGDiuEWopaZJbPoCAKpPacJcYNzDDRB0MGcw1pb7WG4MOOB8C_xoCN7wQAvD_BwE
Posted : 01/04/2021 11:08 pm
currently in stock at mantel here: https://www.mantel.com/uk/shimano-mineral-oil?autocomplete=1
9.99 delivery, but its only 14.99 so not horrendous especially if you need a few more things (up to £135) in the order.
Posted : 28/04/2021 3:32 pm
@pobaker
Mantel now have 1 less thx 😉
Posted : 28/04/2021 3:41 pm
Doh! I've 2 sets of brakes to bleed just done one and proceeded to empty my Shimano mineral oil into the Rockshox oil bottle next to it, same colour! Not sure I trust those eBay sellers selling "genuine" oil. Anyone bought any or fancy selling me some genuine stuff??
Posted : 02/05/2021 3:15 pm
Where are you?
If you can get to Woking quite happy to let you use as much as a bleed needs... I got my Mantel 1l and have the last 100ml or so left of the last bottle.
Posted : 02/05/2021 4:38 pm
I have 3/4l of Shimano oil now use Magura brakes so don’t use it
Posted : 02/05/2021 6:13 pm
