So I want a set of pro 3's with stans rims.
Do I have to use tubeless tyres or can I use any tyres and sealant?
Do I have to use a rim strip on tubeless ready tyres?
If i rip a tyre can I just I throw a tube in with a tyre patch?
Whats good and whats bad.
cheers
Depends. Some tyres are 'tubeless ready'; some will work; some won't. I believe there may be an issue with seating true UST tyres on Stan's rims but I am prepared to be corrected.
Not with Stan's rims - use rim tape and a valve. If you are converting a non-UST rim from another manufacturer, you will need a rim strip (or a ghettoed BMX tube).
Yes.
There is more info than you could possibly ever need in the Notubes.com help centre.
Andy
not so, i run stans 25 mm tape & valve on dt5.1 with some old spesh non ust adrenalines and sealant. Works so well they lose less air than the ust rr & nn i had on before.
Cheers Andy
will check on stans site
Just got some Stans Flow on PRO2's, using Stans tape/Valves/sealant along with Wire Bead Maxxis High Rollers......work a treat!
Maxxis seems to be really good for UST I use them all the time, they just fit so easy no faffing
That is interesting; as I understand it, it's also pretty much how Roval tubeless rims work. I thought the rim strip was meant to be essential to wedge the tyre bead against the rim, though?
Andy
No, it can help but it's not essential. Weight weenies just use tape on the spoke holes. I think with some rims it's more important than others.
You may also find you need a compressor and motorcycle style tyre leavers.
Tubeless is still a bit 'try and see' some combinations work fine with no rim strip, others don't. It's well worth the effort though IMO.
Nobby Nic's on Stan's crest tight to fit but inflate with a hand pump.
Maxxis High Roller (Non UST) Easy Fit, soapy water and compressor to seat at first
All Maxxis variations that I've tried on Flows (with yellow tape) have gone up easily with just a track pump. So far that's:
Minnion 2.35 ST single ply
ADvantage 2.? UST
High Roller 2.35 60A single ply
Larsen TT 2.0 single ply
plus one non-Maxxis so far...Halo Choirmaster UST
Thouroughly recommend tubeless.
Only issue has been from ripping the sidewall a little too easily on the rear tyre when running single ply. Not a problem - just fit a tube. Have since gone to UST on the rear and standard single ply front and am now very happy.
Main advantage for me as a clumbsy rider is pinchflat avoidance. My record prior to tubeless was THREE pinchflats in a single descent of Garburn (at about 40 psi!!!).
Have now been able to drop to 30-35 psi tubeless, definately ride harder than I did previously and remain pinchflat free. The best change I ever made.
