Tell me about Pushf...
[Closed] Tell me about Pushfit BBs.
[#10775487]
Contemplating converting the Pushfit to threaded. Measuring the BB shell I find that it is 87 mm wide.
Surely if I convert it and use external bearings my crank won't fit anyone.
Posted : 21/08/2019 9:08 am
If I have to stick with Pushfit what tools do i need to swap?
Can I just bash them in with a mallet if not point me I the direction of cheap tools please.
Posted : 21/08/2019 9:13 am
Forget the BB is that a pair of Navy crocs with matching socks? 😉
Posted : 21/08/2019 9:16 am
Black all the way brother.
Posted : 21/08/2019 9:21 am
Stick with press fit, I've no reason to complain about the XT ones I run.
As for changing, bash out with mallet & screwdriver - watch the frame. Fit using a length of threaded bar, nuts & washers, or a big bench vice, B&D handyman or a big G-clamp
Posted : 21/08/2019 9:41 am
The Wheels Manufacturing or more expensive hope version , they screw together and the cups stay put so you just tap the bearings out when they wear.
Less creaky & less likely to damage frame when replacing bearings
Posted : 21/08/2019 10:10 am
Mine was very easy to change. Bashed the old one out with a but of dowel, I think I knocked the new one in too. The plastic mounting is soft and will deform to assist you. Of course a bit of care is required but the level of force was not. And it's been fine and creak free. Not seeing an issue with it currently.
Posted : 21/08/2019 10:11 am
No, just very, very, very,very, very, very, very, very, very, very dark blue.
Stick with PF and use a headset press. You can bash them out with a headset cup removal tool.
Posted : 21/08/2019 10:35 am
Looks like a PF41 / BB90 bottom bracket - you can't convert to a threaded BB. As suggested, screw-together designs like Wheels Mfg help maintain bearing alignment and are better sealed than cheaper alternatives.
Posted : 21/08/2019 2:41 pm
That wheels one looks like the way to go. By the time I've bought a bb and tools it will be cheaper.
Posted : 21/08/2019 2:46 pm
My Pivot is a bb92 and the 2 XT's haven't lasted long, a Gusset lasted a while but eventually parted with £85 for a hope been in over a year no creaks or nothing wish I'd gone Hope earlier
Posted : 21/08/2019 2:52 pm
If that’s a Giant, don’t buy the Hope one, it won’t fit.
Posted : 21/08/2019 3:48 pm
It's to fit on this.
https://www.giant-bicycles.com/us/anthem-x-29er-2-2012
Posted : 21/08/2019 4:09 pm
Wheels or Hope is the way to go (or Hambini if you're loaded).
Only one thing worse than crocs,
Crocs with socks.
Hey wwaswas, he got them from a normal shop, they shaft you everytime, but they're good for kicking bishop's up the arse.
Posted : 21/08/2019 11:03 pm
Is the crank 24mm or 30mmm?
Posted : 21/08/2019 11:33 pm
I'm assuming it's 24mm as I offered up a shimano BB and it felt sloppy.
My plan is to use an XT push fit with an XT chainset from another bike. It's a bloody nightmare trying to find out what size I need and whether spacers are needed.
Posted : 21/08/2019 11:39 pm
I've got pf92 on my Jeffsy and stupidly went for a 30mmm RF crankset. Lovely crank but I'm very limited with BB choice by it.
Got a nice sram carbon cs in that psa from a while back to fit over Winter. That will allow me to go Hope or W Manufacturing.👍
The Hope BB I have for pf92 is just 2 push in bearings with a flange.... You can't change just the actual bearings.
Still, lasting ok so far but when it goes the 24mm sram crank is going in along with a better bb.👍
Posted : 22/08/2019 12:39 am
I have a hope push fit bb with xtr cranks on my stump jumper. First one I've ever had. I was worried at first but after a few years running it's been great. From time to time i strip it down, clean it, re fit, still on the same bearings.
If you plan to keep it a while invest in the tools. You can pick them up 2ns hand as people have bought newer bikes with a different set up.
Posted : 22/08/2019 9:24 am
If you go for the Wheels Manufacturing option, just make sure that you have the right size BB tool. If it's like the one I put on my Dude (fatbike) if uses an "odd" size BB tool. Neither of the ones I had fitted so I had to buy a new one. The BB itself was fine though. Easy to fit and creak free for the year or so since I fitted it.
Posted : 22/08/2019 2:41 pm
