Looking at ordering some tech m4s from merlin. I have 183 disc on the front with post mount forks so I need hope mount H. On the rear I have a 160mm disc so do I need brake mount F or can I just bolt it straight on?
Thanks
Posted : 16/10/2011 6:57 pm
Assuming it's an IS mount on the back, you'll still need the adapter because your brakes will be post-mount.
Posted : 16/10/2011 7:02 pm
Is the rear caliper post mount? If it is you will need mount J. If it is a IS mount rear caliper then it will bolt right on.
I haven't bought them yet so don't know if the rear is IS mount or post. The frame is IS
Posted : 16/10/2011 7:04 pm
Forget my second statement Hope tech M4 are post mount calipers, so you will need adapter J.
Posted : 16/10/2011 7:05 pm
Thanks.
Posted : 16/10/2011 7:09 pm
