Taking the Nomad &#...
[Closed] Taking the Nomad 'squatting dog' theme just a bit too far?
14 Users
(image shamelessly stolen from a brant twitter)
Posted : 16/04/2010 7:55 am
Posted : 16/04/2010 8:06 am
That really is very fugly, though fitting a frame around a three-mile long shock is always going to be a bit tricky.
Posted : 16/04/2010 8:07 am
 hora
Why is that frame needed? For Josh Bender? 😆
Posted : 16/04/2010 8:12 am
it's probably only got 6 to 8 inches travel hora - the shock is a a 2:1 Carnutt thingy.
Posted : 16/04/2010 8:13 am
'the bells, the bells!'
Posted : 16/04/2010 8:16 am
It's got a little Fox sticker on the piggy back...
Posted : 16/04/2010 8:19 am
It'll still have a 2:1 stroke though, won't it?
Quite a startling looking bike.
At least if you were riding it you'd probably have a full-face helmet on so nobody would know it was you.
Posted : 16/04/2010 8:49 am
I would love to try a Foes, they have thrown a LOT of money at that in design and R&D.
Is it a development bike or production?
chapking, it certainly looks like Fox 2:1 shock on it, maybe Fox are in on the devolpment of this instead of Carnutt...
Posted : 16/04/2010 8:52 am
Very true, I didn't think about the length of the shock just focused on the name. If Fox are working on a 2:1 capable shock could that mean more bikes with such a leverage ratio in the near future?
Posted : 16/04/2010 11:55 am
And that would be a good thing why?
Posted : 16/04/2010 3:27 pm
I've not ridden one, so I'm not 100% sure it is a good thing. But my understanding is that a lower leverage ratio produces a smoother suspension action.
Posted : 16/04/2010 3:34 pm
Because everyone tells us that low leverage ratios are better?
lower leverage ratio = higher oil volumes + lower internal pressures = better and more consistent performance.
Posted : 16/04/2010 3:49 pm
The Santa Cruz website has some interesting articles on this subject stating that they cannot remotely tell the difference between a 2.75" stoke versus a 3.5" stroke for 10" of travel but that it did seem to make a difference going from 57mm to 63mm on the Blur (sorry to mix the units)
Posted : 16/04/2010 4:32 pm
How does that work for light riders?
Posted : 16/04/2010 4:36 pm
I was just repeating whats been beaten into me by magazines/internet articles 😉
Posted : 16/04/2010 5:09 pm
Brant, if the correct spring rate is chosen, why would the weight of the rider have any bearing on the leverage ratio?
Edit: If 2:1 became more the norm would lighter spring weights become more common?
Posted : 16/04/2010 5:16 pm
i like the looks of it,, who needs straight lines when a nice curve does the job
Posted : 16/04/2010 5:26 pm
Mildred is getting warmer.
Posted : 16/04/2010 6:16 pm
From my own fannying around with my Nicolai in the various travel settings using a variety of shocks i found that the lower the leverage ratio, the lower the spring weight or psi needed. Using a too long Dhx air shock on the lowest travel setting I achieved a 2:1 (thereabouts) ratio.
This had an interesting effect - the compression damping was incredibly slow. I wondered if this is because the Dhx air is designed to be used at higher leverage ratios? I rang Mojo to ask, but they said not, and that a standard Dhx air should work ok with 2:1. From comments above, this may be in dispute:
My own guess is that it isn't that good at flowing oil through the damping circuit, so brant, you're more than dabbling with full suspension and [i]Linkage[/i] at the moment, can you shed any light?
Posted : 17/04/2010 1:31 pm
