Swapping shock, do ...
[Closed] Swapping shock, do I need to remove this...
4 Users
Silver ring bit? And if so how?
Posted : 13/03/2011 8:46 pm
It's called a DU bushing.
If your new shock doesn't have them, then you'll need to install one at each end. I'd use new ones rather than the ones from the old shock - they are very cheap and are disposable items.
To do that you need a special tool (although you can manage it with a socket set and a hammer if you are careful).
Posted : 13/03/2011 8:55 pm
 Taff
Think I paid less than a £1 ea from Mojo before and just tapped it on or used a vice.
Posted : 13/03/2011 8:57 pm
If you are fitting a new shock the chances are you have them in it already. Simple check; pop the 'top hat' in the end of your new shock if it fits snug then it's good, if it rattles round then you need to fit a bushing.
Posted : 13/03/2011 9:00 pm
Thanks chaps 🙂
Posted : 13/03/2011 9:08 pm
