Swapping Maxle type...
[Closed] Swapping Maxle types
I have a Whtye T-130 which has a maxle on the rear, I also have a Bird Zero TR which has a maxle light on the rear. Is there any reason they are not interchangeable? I prefer the way the maxle light works and I'm thinking I could buy one to replace the 'standard' maxle on the T-130 - anyone do this or know why it would be a bad idea?
Posted : 10/07/2016 11:06 am
Bump in the hope someone might be able to help
Posted : 12/07/2016 7:14 pm
If the lengths and thread pitches are the same, it will be fine. Easiest way to check is take both out and see if the threads mesh / line up.
Posted : 12/07/2016 7:57 pm
I recommend replacing with a bolt up version like those from Mt Zoom. Work better, weigh less, cheap.
Posted : 12/07/2016 8:10 pm
Cheers will compare the two types
Posted : 12/07/2016 8:35 pm
