Stack and Reach com...
[Closed] Stack and Reach comparison tool
I'm looking for a comparison tool/site to compare some frames/bikes.
Anyone got a link to an easy to use online tool?
Posted : 11/04/2017 7:28 am
[url= https://geometrygeeks.bike/bike/bird-aeris-145-2017-1/ ]The only one I know of[/url]
Posted : 11/04/2017 7:39 am
thanks
Posted : 11/04/2017 8:06 am
Another [url= http://yojimg.net/bike/web_tools/stem.php ]one here that shows an overlay of stem height/length differences[/url]
Posted : 11/04/2017 8:53 am
Link not working for me?
Posted : 11/04/2017 10:17 am
Its a total minefield as bike companies often dont compare like for like, with different length forks to what are specified or not telling you if they are using sagged suspension. I use an [url= http://gearinches.com/blog/misc/bike-geometry-comparator ]excel tool[/url] and compare each bike manually, adjusting as required to understand what the real differences are.
Posted : 11/04/2017 10:34 am
I've been doing this recently, it's a disaster as some take stack to top of headset, some state stack "assuming 15mm spacer" and some show diagrams with stack taken to the top of the stem clamp (which therefore also includes some arbitrary number of spacers, not stated).
Reach seems a little more standard, although even then one manufacturer states "assuming 100mm stem" (although at least they state it, and subtracting 100mm from the figure wasn't too much of a struggle...).
Posted : 11/04/2017 10:44 am
@granny_ring try https://geometrygeeks.bike/
Posted : 11/04/2017 11:15 am
@13thfloormonk yeah I bet it is a mare. Given stack and reach both use a fixed (the same fixed) point to measure to you wonder why so many bike companies get it wrong... or is it deliberate?
Posted : 11/04/2017 11:16 am
http://www.bikegeo.net/
Allows you to compare different bikes easily by putting in your own figures. Also shows that having bars in the same position from the floor makes more sense of manufacturers reach figures and bikes with big differences on charts end up being very similar when you take account of your normal bar height set up.
Posted : 11/04/2017 11:19 am
Some are just outright lies and once you plug all the supplied numbers in to a spreadsheet, nothing lines up.
Posted : 11/04/2017 11:42 am
Yeah a good example is the new Rocky Mountain Slayer - the reach numbers are around the same as my Reign - however its a fair bit longer than it appears to be on paper because of the massively long headtube.
Posted : 11/04/2017 12:33 pm
