Hi can anyone tell me if a sram xx gxp crank will fit in my BB92 frame,is the spindle on the xx crank bigger than 24mm?
Posted : 29/12/2010 6:54 pm
IIRC GXP spindles are stepped, so if you're using Shimano/FSA BB cups, it won't work. You should be able to get GXP BB92 press-fit bearing cups that will work fine though.
Andy
Posted : 29/12/2010 7:07 pm
Cheers will have a look around.
Posted : 29/12/2010 8:04 pm
As above, The Shimano ones won't take the stepped axle but you can get XX press in bearing cups, a lot of bikes run them now.
Posted : 29/12/2010 8:11 pm
Yep, but you do need the GXP chainset, the BB30 one does have a fatter axle. May mean paying for a GXP BB you dont need!
Posted : 29/12/2010 10:06 pm
