SRAM eagle AXS chai...
SRAM eagle AXS chain line issue - what am I missing??
[#13535911]
So I’m stumped (pun intended as you’ll see later!) and I’m hoping someone can suggest some checks I haven’t thought of or point me in the direction of a fix
issue - chain falls off front chainring when in gear 1 (50T) or 2. It looks like the chainring is too far outboard
bike - my mates Specialized stumpjumper Evo alloy 2023
How did I get here?
I swapped the original, old rear wheel and cassette for a Stans Flow mk4 with Hope Pro5 hub (XD) and took off the sram 12x cassette (the one that comes apart in lots of pieces) with an XG-1295 cassette and the NX mech with a new GX AXS mech
Cranks are NX with 3mm offset chainring
BB is sram dub with 4.5mm DS spacer
Hub and frame are 148mm boost
(wheels were previously on my orange stage Evo running an XG-1299 cassette and X01 AXS)
I tried a 2mm spacer behind the cassette and that “works” but obviously not going to keep it like that
So I’m stumped as when it’s set up as it should be the chain falls off the chainring (pulled towards the bike) as if I’m trying to run a 6mm offset chainring or have a 49mm chain line
any thoughts?!
Posted : 13/06/2026 2:07 pm
How worn is the chainring? Are you using a new chain?
Posted : 13/06/2026 8:38 pm
Chainring isn’t worn. Has probably 100 miles on it, same with chain.
I put in another hope pro 5 wheel with another XG-1295 cassette (one of my spares) and that is fine in 1st and 2nd so it must be something with the hub/freehub and spacing on the problem wheel.
ran out of time yesterday so will strip the hub today and check everything
Posted : 14/06/2026 5:32 am
4.5mm drive side spacer seems a lot ..
Posted : 14/06/2026 2:12 pm
That’s the correct size according to sram for that BB, crank and chain line.
It looks like it was something to do with the rear freehub as I removed that from the wheel and stripped/cleaned everything and reassembled and it seems to be fine now. Very odd but I’m not going to complain too much as it’s working!
Posted : 15/06/2026 5:40 am
