I rode the bike a couple of days ago and was fine. Today got on it and the lever is pulling to the bar and brake not working... presume it probably needs taking apart and bleeding?
Anyone got any thoughts on a quick fix? Thanks
I'd be asking where the air has come from first, have you stored it upside down and drawn in air that was already in the reservoir, in which case a bleed may well sort it, or has it got in elsewhere, in which case that'll need sorting first.
Stored the right way up, in the house. So, I’m guessing it’s probably not as simple as just a bleed?
Probably not, how worn are the pads, any squealing (possible leak at the caliper contaminating pads), any sign of fluid leaking around the reservoir or hose connections?
I need to have a proper look, but that was my thoughts as well. Probably take it to the LBS if they are open / post-lockdown....
Worth checking the reach adjuster? Mine (same type) kept vibrating loose on bumpy rides making the lever pull to the bar before the brakes fully engage. Have a look at both lever positions and see how they compare.
