Specialized 2Bliss
[Closed] Specialized 2Bliss
[#568693]
can someone confirm whether you can use Specialized 2Bliss tyres on a conventional rim (with inner tube) or just use them on a UST tubless rim?
cheers
Posted : 20/05/2009 9:10 pm
You can use them with tubes, and to be honest, they are the work of the devil, and never inflate without them, even on tubeless rims.
Posted : 20/05/2009 9:17 pm
 aP
I'm using Captain's on X819 rims with Stans liquid and they're fine. went on easy, inflated pretty easy, took about 20 minutes to seal, have worked for 4 months.
Posted : 20/05/2009 9:19 pm
thanks aP
Are the X819 UST or standard rims?
Posted : 20/05/2009 9:27 pm
 aP
They're UST rims, sorry.
Posted : 20/05/2009 9:30 pm
Swiftacular - Member
I can confirm that this is utter shite
Posted : 20/05/2009 9:46 pm
They need sealant, and folk think they don't. I liked the Sauserwind I had, tubed and tubeless.
Posted : 20/05/2009 9:50 pm
Quite clearly stated on the adverts that they require sealent
Posted : 20/05/2009 9:52 pm
 daim
I use 2Bliss Eskar 2.3 "super-ghetto" (just tape, no cut up tube as rim strip) on non-UST Halo Freedom Disc wheels. They are superb. Inflate easily and have no air loss at all using Stans Sealant.
Posted : 20/05/2009 9:55 pm
 aP
They were much better than the Jones TR set I had which ripped open both sidewalls within 30 miles, although the Jones Dry TR I used for Bristol 12 and more last year were great. Actually they might come out in 2 weeks if the weather is right.
Posted : 20/05/2009 10:11 pm
I'm using the Eskars on Stan's Flows. Perfect inflation.
Posted : 20/05/2009 10:12 pm
Eskars on 819 UST, can't recommend them highly enough.
Posted : 20/05/2009 10:15 pm
seconded
Posted : 20/05/2009 10:18 pm
Slight Hijak, can all those eskar lovers out there confirm how big the 2.3" width come up.
I am looking at replacing a 2.35 Maxxis HR with these and but I dont want to go much bigger in width.
Posted : 21/05/2009 8:49 am
Have any of you lot actually read the question properly?
cheers
[u][b]on a conventional rim with inner tube[/b][/u]
Well, have you?
One person has, the rest are all blathering on about tubless.
So, to answer your question PROPERLY -
Yes, they work fine on standard rims with a tube. Lots of Spesh bikes are supplied with them like this, like the Eskars on my Pitch.
Posted : 21/05/2009 9:02 am
Which tyre doesn't work on a standard rim with a tube?
Posted : 21/05/2009 10:03 am
??? The first reply answered the original question, why are you answering it again? It also suggested they don't work well tubeless, hence the other replies.
Posted : 21/05/2009 10:09 am
Yes they work fine as a standard tyre on a standard rim.
But then so do pretty much all tyres (UST included, although why you'd want to do this is beyond me).
I run an Eskar 2.3 tubeless on an 819 - it's great. Went up easy and no air loss.
The 2.3 is a decent size (ie. not undersized like 2.3 high rollers). Seems almost identical in size to the new maxxis 2.25s (advantage, ardent etc).
I also really like the way there are 3 different versions with different sidewalls, so you can choose your weight to toughness ratio as suits you.
Posted : 21/05/2009 10:30 am
Hi sorry for the Hi Jack
Peter i have a pitch pro and it cam with the eskars and tubes
are the rims supplied UST compatible? thanks DTD
Specialized supply the Captain 2Bliss on standard rims with tubes on this years Stumpjumpers!
Posted : 21/05/2009 10:33 am
the pitch comes with DT-Swiss 445D rims which i cant find on DT swiss web site ? anyome know if these are tubless cmpatable rims? thanks DTD
Posted : 21/05/2009 10:39 am
Only with a rimstrip.
Posted : 21/05/2009 11:00 am
Use a stans kit with the standard rims and you'll be sorted.
Eskars don't come up too huge, not as big as the Spesh resolutions I used to run
Posted : 21/05/2009 11:27 am
