Small split/tear in...
[Closed] Small split/tear in the sidewall of a high roller....
6 Users
Just got back from a ride in the lakes, and on cleaning my bike discovered a 1cm (approx) tear/split in the sidewall of my rear tyre (maxxis high roller,60a,single ply,2.35"). You can see the tube, and it is poking through slightly. Can this be repaired/patched somehow, or should i get a new tyre?
Posted : 28/03/2010 5:21 pm
Repair would be a bodge in an emergency .New tyre time really.
Posted : 28/03/2010 5:25 pm
 Chew
If the split is less than 1cm you can just patch it up and keep using it.
You should be able to get a patch from somewhere, or just use a punture reapair one.
I've done the same 6 months ago and ride on the tyre 2-4 times a week.
Just keep an eye on it. If the split gets bigger replace.
Posted : 28/03/2010 5:46 pm
 IA
I've gaffered (use a couple layers) the inside of tyres before, and then ran them 6 months with no issues. Give it a go.
Posted : 28/03/2010 5:50 pm
 br
patch the inside, superglue the outside - works fine, even when tubeless
Posted : 28/03/2010 6:49 pm
I've got a good few months of use out of Park Tool tyre boots before. They're supposed to be emergency use only tho...
Posted : 28/03/2010 7:33 pm
