Single speed - use ...
[Closed] Single speed - use QR or new axles required?
I am starting to build up a SS frame. I have a QR Hope pro hubbed rear wheel handy that I thought I would use (with spacers). The frame has sliding drop outs and have heard better not to use QR. If that is the case do I need to get longer axle and use nuts? Is that an easy conversion on the Hope hub? Help appreciated.
Posted : 10/10/2011 2:22 pm
QR will be fine. if you have sliding dropouts the actual axle will be held firmly by the dropouts.- all the QR is to do is to stop the wheel falling out if it comes off the ground.
Posted : 10/10/2011 2:24 pm
Thanks www. I thought though there was danger of the wheel slipping forward in the dropouts (loosening chain). If not, great - makes things simpler.
Posted : 10/10/2011 2:36 pm
I would only do it with a good (e.g. Shimano) QR skewer.
I've torn the wheel out of the dropouts a few times with QR rear. They need to be VERY tight. The Mavic skewer had to be so tight I thought I was going to break it, but that was just after tearing a wheel out so there was no doubt that I needed more tension.
Posted : 10/10/2011 4:28 pm
not with sliding dropouts.
do you mean something else?
Posted : 10/10/2011 4:31 pm
do your dropouts look like this?
or this;
the first is a slidign dropout.
if you have the latter get a chaintug (DMR, etc) on the drive side and you can still use a QR.
[edit] google images to the rescue 🙂
Posted : 10/10/2011 4:32 pm
LOL!
Posted : 10/10/2011 4:45 pm
Yes I have second picture (track ends??) - terminology wrong. What frame is the first pic?
Posted : 11/10/2011 8:39 am
Track ends - I've done a 24 hour solo 'Puffer with QRs and a chaintug (a skinny cheap one fitted to the inside of the dropout).
It didn't move.
Posted : 11/10/2011 9:40 am
get a dmr or on-one chain tug (or surly if you're felling posh) and you'll be fine with a QR.
I did have to file my dmr chaintug down a bit to use with my carbon456 as there isn't much clearance around the dropouts but it keeps the hub in place which is the main thing.
Posted : 11/10/2011 9:43 am
Sorry for the thread hijack!!! Can you use a QR with a SS conversion kit with "normal" vertical dropouts?
cheers!
Posted : 11/10/2011 10:09 am
yes.
Posted : 11/10/2011 10:10 am
I've had a few nightmares with QR's on track ends - if I were you, I'd get a solid nutted rear axle to be sure. 😀
Posted : 11/10/2011 11:18 am
Seems like the jury's out! Not sure if Hope do a solid axle version (they do bolt in which I gues would do...) but am thinking worst case will gice chain tug a go. Now I understand that the single cog will damage the (alu) freehub on the Hope - replacement steel one is £60 - aargh!! May gave to start another thread on cheap SS rear wheel build...
Thanks for comments.
Posted : 11/10/2011 2:00 pm
get an groove armada cog from on-one - very wide at the base - I've had no issues on my Hope hub.
Posted : 11/10/2011 2:01 pm
You can get allen head qr's that would fit a hope hub.
but really a chain tug/ tensioner would stop the hub moving.
Posted : 11/10/2011 2:02 pm
www - that is a great shout - did not know they existed - will give that a go.
Posted : 11/10/2011 2:13 pm
