Hello looking at a superlight as an enduro race bike, ideally the older one pre 08 (is that when they redesigned the swing arm?) any opinions on the build and estimated weight? Also can I put on a 120mm fork?
hello to the evening crowd 😀
shortcut
any idea on the weight of that? Looks nice.
No idea at all probably about 25lb, not built to be light, just comfy for long rides. It is a large and I'm no lightweight!
Does it climb ok? Not being very fit I need all the help I can get!!
Yes, a good climber. Not too much bob! Pretty reliable, goes through bushings though and not as well built as say a turner in terms of straightness and tolerances.
Just finished throwing it together, not really finished yet as a few bits are leant out or on my other bikes (wheel, brakes), new shape from 2007. Only had a spin round the local park so far with my kit, though have ridden it for 2 week last year when I my m8 first mentioned selling it. Fantastic piece of kit.
[img] http://images.fotopic.net/?iid=12hh3p&outx=760&quality=70 [/img]
mines not been used yet... (not that the previous owner used it a whole lot either)
Here's a pic of my new one the day it arrived a few months ago
I also have a 2002 Superlight which is the model I think your refering to vondally, also a very good bike, that one's about 26lb but it has better wheels than the new one, but after riding the new one I do notice the rear end being a bit more flexy. I found the main pivot bearings to last ages on the old one but the lower shock bushes would wear quicker, don't know what the new one will be like yet for pivot and bush wear, you should be able to pick up a nice will speced older Superlight for a reasonable price?
This is mine, got the frame from here for £300 last year. I absolutely love it. Now with 130mm Revs, HTII crankset and bigger anchors.
The bushes and bearings were very loose when i got it but i think they were the originals from '03. It has done a hard year on the new ones and with the exception of the bolt coming loose once they feel as good as new. It's only £20 for the full set anyway.
I suspect the new design uses bigger bearings and mounts them in a more sensible way, probably slightly lighter too. The older design doesn't have a replacable hanger either, but the hanger is so chunky that it will be the mech that gets destroyed, not the frame.
aRE THERE ANY GOOD DEALS ON THESE FRAMES ANYWHERE?
DON'T SHOUT! 🙂
Removes ear plugs....
Sorry 😉
Great folks v8 the 130 forks are okay on the frame then?? was thinking of 120mm max so guessing will be okay??
