Get harder to unclip the more worn they get ? Surely it should be the other way around?Dug out a pair of shoes that are years old but with plenty of life left in them jeez it's scary trying to unclip from the damn things, looks like I might have to put new cleats on ?
Because they need the metal there to disengage the spring.
Unsure but maybe it requires a substantial and machined edge to trigger the release. Tips:
1. Dont buy ebay fakes (buy from a recognised bike / sports seller)
2. Clear out the hex heads before FULLY inserting your best quality (not ikea flat pack) hex. I use a 2mm drill bit or Dremel to drill the crap out dentist style.
Not sure I agree. I tend to replace mine when they start to randomly pop out of the pedal...usually when trying to jump or hop over something!
Maybe I'm leaving them too long?
Also depends on how much tension you got the pedal set at, if you wind off the tension at the pedal, worn cleats can release a bit easier.
Yeah @nickc I recently changed the pedals , I always wind the tension right out until my feet nearly fall out then back in a couple clicks . I hate being so connected that I struggle to get out.
Blimey you’re brave. I use a pick and some water to soften the debris
I think what happens is that you end up trying to unclip from the front of the cleat, rather than the rear.
In theory, when you swing your ankle out you pivot from the tip of the cleat and slide the back edge along the sprung part of the pedal mechanism.
I've noticed when it all gets a bit sloppy I end up pivoting on the back edge of the cleat and swinging my toes in to the crank in a way its not really designed to release from.
I agree with the weird feeling though.
Also - has the pedal clip plate worn a groove in the shoe midsole just behind the cleat? If so, and you have your weight on the pedal as you unclip, you end up trying to lift your bodyweight up too to slide the pedal out of the worn patch of midsole.
How do ypu wear them out ? Mine last ages .
Every pair I've ever worn out have released to easily rather than becoming more difficult. Even with the pedal tension cranked right up the last set popped out with minimal provocation. Usually when trying to lift the wheel or hop over something.
Top top...
When that happens and you but a new set of cleats, remember to loosen the pedals off before your first ride.
I also find that the after a couple of years my cleats wear the pedal where it contacts on the softer aluminium. This results in the cleat and shoe not rotating/floating as it should. Does this happen for anyone else?
woody71
I didn't think the cleat was in contact with aluminium?
I do find my shoe lugs wear away the aluminium sides and result in play/rocking of said shoe. This is annoying as I've never yet needed to service a Shimano pedal (always avoided XTR btw), because the body always wears out long before the bearings need any attention. The speed the body and cleats wore away when I used to singlespeed was quite alarming. No wonder my knees are much better with gears.
When cleats wear out I do find they sometimes catch while trying to unclip. But ultimately when really knackered they just pull straight up out of the pedal.
Mine don't. They get easier and eventually the pedal wears away as well.
They seem to get inconsistent for me?
They start off nice and positive and take a bit of a kick to get out but they release with a big CLICK. Then they get loose, but the release needs more force and gets less positive.
Could be worse, Shimano steel cleats last ages whereas the brass ones on time or CranBrothers last a winter (if the pedals lasted that long)!
Have you considered trying Crank Bros?
I think he just wants his shoe to detach from the pedal.
Not the pedal from the crank.
I was under the impression that it will be cockroaches and Shimano cleats that outlast humanity.
To be fair, the axle is usually left behind.
Not always in my experience.
I often wear shoes out before the cleats. Probably over 10k miles on the current road/gravel set.
New ones fitted , that’s better, part of the secret to getting them off is copper grease on the threads when you fit new ones.
That’s worked for me too - as has using Loctite thread lock.
