Shimano brakes - wh...
[Closed] Shimano brakes - which ones for best value/power?
Now you've mentioned going t'Alps - Zee is the right choice yeah
Posted : 22/11/2017 1:38 pm
 wl
Brakes are for my hardtail, which won't be going to the Alps to be honest. Even so, that extra Zee power will still be welcome, and 'fitness' has a good point above.
Posted : 22/11/2017 1:52 pm
Moved off Hopes 10 years ago as found them dreadful and very needy three years running in the Alps. Now thinking of returning as they just seem more consistent.
I've XTs but if I was buying again would be sticking to Deore or SLX.
Two sets of Deores here, both have suffered bad fade, moving bite points
Ditto on both previous sets of M775 XTs and one of my set of M785 XTs is heading the same way. Can be recovered for a little while with a good bleed. These seem very finicky about pad wear and it really compromises the lever.
never lost a drop in 18 months, but first pull was a bit of a mystery pull you could slow, or just find the bar, nothing I did could fix it,
Ditto again but only rears!?
Posted : 22/11/2017 2:24 pm
Page 2 / 2
