I want to change all screws to coach bolts on my shed.
however all bolts I can see on e-bay have a nut shape on the back of the endcap...obviouslt this will not allow the bolt to be flush to the hinge.
other option is a hex bolt (countersunk)
what size m5 or m6?
also can anyone recommend an alarm that sounds in the house?
and a decent security light?
thanks
Craig
[quote=sefton said]
I have one of these, works well.
http://www.amazon.co.uk/gp/product/B0045U0L96
I found with coach bolts the 'square' bit cut into the round hole in the hinge as it was done up tight. You had the dome of the bolt head standing proud but the rest was flush. It also means the bolt can't be rotated at all as it's locked by the hinge.
so one sensor in your shed and one sensor in your garden? hmmm
Just use standard countersunk head machine screws, and a big washer and two nuts on the inside.
I'm with wwaswas on this. You could just drill out the hinge a fraction to allow the square section to pull tight a little easier too.
[quote=sefton said]so one sensor in your shed and one sensor in your garden? hmmm
I have the sensor in my garage and the alarm part in the house. Outdoor sensors tend to be too susceptible to false alarms IMO.
Aye, the local foxes here would have me out every night .
Shear bolts came with my Shed Shackle, [url= http://www.securityfastenersandfixings.co.uk/Info/shear-bolts-19.aspx ]similar to these.[/url]
As it prevented scrotes nicking off with your bikes? There's been some burglaries round here recently and I want something similar. I just imagine they'll rip if off and pull the batteries out or some such!
Cheers,
Jamie
[url= http://www.diy.com/nav/fix/nails-screws-fixings-hardware/nuts-bolts-washers/Cup-Square-Bolt-AVF-851735-Pack-Of-10-W-M8-x-L-130mm-9708022 ]Coach Bolt (probably no good, as the heads are still domed)[/url]
[url= http://www.diy.com/nav/fix/nails-screws-fixings-hardware/nuts-bolts-washers/coach_screws/Coach-Screw-AVF-850912-Pack-Of-10-W-10mm-x-L-65mm-9707988 ]Coach screw (probably what you were looking at, at no good either)[/url]
[url= http://www.ultrasecuredirect.com/acatalog/shed_security_wireless_battery_pir_siren_alarm_007-0300.html ]Wireless Shed Alarm[/url]
The one that I linked to has a siren built in and a remote one that you can have in the house, meaning that destruction of the one in the shed doesn't stop the other one from going off.
Also, you could look at [url= http://www.ampwire.co.uk/shop/category/PIR-Guards/75 ]something like this[/url]
[url= http://www.toolstation.com/shop/Screws+Fixings/Coach+Roof+Bolts/Roofing+Bolt+M6+x+80/d90/sd1670/p97967 ]toolstation bolt linky[/url]
you are looking for roofing bolts.
As has been said, drill your hinges to accept the square protion of the coach bolt or change your hinges, cheap enough.
If you have power in your shed/outhouse baby monitors are good ..
might just put hex counter screws in (they will be bolted inside)
dont fancy bodging/drilling to fit the square portion of the coach bolt.
whats a good bolt width?
regular hasp or one of these? http://www.ebay.co.uk/itm/FEDERAL-HIGH-SECURITY-SHED-VAN-LOCK-BRACKET-HASP-FD3055R-/321050415330?pt=UK_HaG_Lock_Safes_GL&var=&hash=item76c40f29c2
