Servicing DT Swiss ...
[Closed] Servicing DT Swiss EXM 150 (26") - oils
[#11005422]
Am i ok to swap out the DT swiss specific stuff for Fox float fluid and 7.5wt for damper and lowers?
Posted : 14/01/2020 10:37 am
for the lower i imagine it would be fine but for the damper i would investigate further
Posted : 14/01/2020 10:47 am
classic fork right there.
Greg @ TF tuned is the man to talk to regarding DT fork servicing. They can supply the correct oils as well if you're looking to DIY.
Posted : 14/01/2020 11:12 am
thanks
Posted : 14/01/2020 11:24 am
The best ever of the DT Swiss forks to my mind - simple, just keep working and you can take everything apart at home - had mine for 3years with zero issues. Anyway for the lowers - FLOAT fluid is fine in the spring side and the most readily available. For the damper (cartridge+lowers as the oil does both) I found the best to be Motorex 7.5wt - again, readily available.
Another tip-if you take apart the airspring assy. then use grease such as SlickHoney - over time oil blocks the ABS ports up, leading to harsh top-out. When you remove the airspring (which you can do from the bottom of the stanchion), take the air-spring assy. and squeeze the ABS spring to expel the oil from the foam washers.
Posted : 15/01/2020 10:32 am
I think DT have finally surpassed them with the new F535s, which are superb, but yeah, of the old reverse arch DT's the EXM's were a prime example
Posted : 15/01/2020 11:24 am
I've read mixed reports of the F535 but the main con for me is that the more in-depth service details are still locked-down (unlike Fox and RS).
Posted : 15/01/2020 12:13 pm
You should use Motorex SAE 7.5 for the damper and Motorex Supergliss 100K for lubrication.
Posted : 16/01/2020 8:05 am
Yep, as already already said above use (readily available) Motorex 7.5wt, but good luck in getting Supergliss 100K in the UK - which is why I recommended the available alternative of FLOAT fluid.
Posted : 16/01/2020 12:11 pm
TFTUNED recommended 7.5wt in the damper and 20wt in the lower/spring side
Posted : 16/01/2020 1:33 pm
