Sectors travel incr...
[Closed] Sectors travel increase?
3 Users
Random question, can you bump the travel on a Pair of 27.5 140mm RS sektors to 150mm
Increasing travel by 10mm takes 0.5 degree of the head angle right?
It raises the Bb by a tiny bit, does it decrease reach also and by how much?
Posted : 18/12/2015 2:51 pm
 LoCo
yes you should be able to increase travel, depending on spring system.
HA roughly yes.
bb and reach wise, it's won't be enough to cause a huge difference.
Posted : 18/12/2015 3:14 pm
Thanks
They're solo air ones, I think "gold rl"
Posted : 18/12/2015 3:22 pm
 LoCo
There maybe a spacer in the air system that can be removed to extend them, if not you'll need to change the air spring to a 150mm assembly.
HTH 😀
Posted : 18/12/2015 3:24 pm
Ah ok, rough idea of cost?
Thanks!
Posted : 18/12/2015 3:31 pm
 LoCo
Fairly easy job to remove at home if you're a happy with spannering.
Check to see if you have a spacer first, you could do a lower leg service at the same time.
Link to service guide:
Posted : 18/12/2015 3:33 pm
Brilliant,. Thank you!
Posted : 18/12/2015 4:03 pm
Hi
So I followed the manual, took out the spacer and the forks now sit at 150mm
Result, except I just went for a test ride and only got 125 travel out of them on a descent I'd normally have expected to get the fork to bottom out at 140mm where it was previously set.
Did I cock something obvious up?
Posted : 20/12/2015 4:24 pm
At a longer travel you might need less air pressure. The did I cock it up question is easily answered by letting all the air out and checking if the fork compresses all the way down
Posted : 20/12/2015 4:29 pm
Thanks
So with all the air out and my weight on it, it compresses down to the fork crown - full travel. If I take my weight off it, it rises back up about 20mm very slowly
Is that right?
Maybe I just rode especially smooth and light today?
Posted : 20/12/2015 4:41 pm
I would try another ride with a bit less pressure and see what happens.
Posted : 20/12/2015 8:37 pm
Will do!
Posted : 20/12/2015 9:18 pm
