Seatpost slipping -...
[Closed] Seatpost slipping - help
5 Users
I've had an issue with my seatpost slipping for a while now. It's a KCNC SC Pro Lite post in a Kinesis XC Pro 3 frame. The fit is [i]very[/i] tight - I have to use force to get it in and out, so it's not as though it's too loose. I imagine that when I go over a bump and my ghetto booty hits back onto the saddle hard enough, it is forced down. I'm not exactly a fat b'stard, 83kg, so it probably shouldn't be happening.
I was using a light KCNC seatclamp, which has been replaced with a slightly heavier duty no-brander, but the problem persists. Is there any way to remedy the situation?
Posted : 28/02/2013 3:42 pm
My Marin did that. I cleaned out the grease inside the seat tube (oops) and used anti-slip stuff instead. With a wider tighter (QR) seat clamp it was fine.
Posted : 28/02/2013 3:46 pm
My friend you need carbon assembly paste.
As above carbon assembly paste you will barely have to tighten the seatclamp.
http://www.wiggle.co.uk/ritchey-liquid-torque/
There's enough in that sachet for several seatposts & bars
Posted : 28/02/2013 4:02 pm
 JoeG
How about a double seatpost clamp?
Posted : 28/02/2013 8:40 pm
