about to set a 5 yer old magic EN521 rim up tubeless. will presto tubeless valves work given that it has a schrader valve hole?
cheers
James
yes.
Yes but you're best off sourcing a conversion bung or you may end up forever chasing leaks around the valve. Like these have as an example - http://www.effettomariposa.eu/en/products/caffe-tubeless-valve/
Why not use tubless schrader valves?
I coulndt get a seal when I used a conversion bung.
Used proper valve - no issue.
Tubeless schrader valves are a far better idea. Now that rims are wide enough I think it's time for MTB's to bin presta valves. Once you've used one you'll not want to go back.
Have used both Mavic tubeless presta valves and presta valves chopped out of old inner tubes in rims that are drilled for shrader, both worked fine.
FWIW one benefit for presta is that you can get the valve core out with pliers, whereas shrader need a special tool. Other than that shraders seem to get less bunged up with latex and it looks like a bigger hole, which would help a little when seating the beads
I use the Stans Schrader valves on my hugos - they were easier to set up tbh as the hole with the core removed is bigger.
Wish all tubneless valves and rims were that size!
