Dishing a wheel off...
[Closed] Dishing a wheel off-centre?
[#8409648]
Is it possible/safe to dish a wheel off-centre?
Basically, the bike I'm making (single sided rear end) needs the rear wheel to be dished to get the freewheel onto the correct chain-line by approx 10mm off-centre (and keep the centre of the rim central to the frame).
It's a 16" wheel so short spokes and lightweight rider, if that makes any difference?
Posted : 21/03/2017 10:25 am
It'll be fine, you may need to alter spoke lengths though.
I think Cannondale so that on some of their fatter mtb's now to get chainlines and tyre clearances sorted.
Posted : 21/03/2017 10:31 am
Do you mean is it ok to have the spokes shorter on one side? If so most wheels end up being built that way, so crack on! 🙂
No problem at all. The aim is to get the rim in the middle of the frame. Whatever it takes to achieve that.
Posted : 21/03/2017 10:32 am
My old Pace frame had an offset rear end to give a stronger wheel, I think it was dished about 3mm from centre. So long as your spokes take a reasonable angle from hub to rim no problem
Posted : 21/03/2017 10:36 am
Thanks gents, I'd hoped that was the case 🙂
Posted : 21/03/2017 10:37 am
I've had to re dish my rear wheel by 6mm to fit in my Fastforward frame.
Took about 10 minutes and used the same spokes.
From memory it was around a turn and a half on the nipple to move the rim 6mm.
Posted : 21/03/2017 10:40 am
I had to do this on a Demo 8 its perfectly fine.
Posted : 21/03/2017 10:48 am
