I have the 80mm versions: This is probably a silly question but does anyone know if it is possible to increase the travel to 100m?
Yes, almost certain. You just remove spacers.
you usually get the spare spacers with them
bassspine - Memberyou usually get the spare spacers with them
The spacer reduces the travel.
yeap. Its a spacer adjustment. I think they can go to 120mm......
S.
[i]yeap. Its a spacer adjustment. I think they can go to 120mm......[/i]
That will depend on the year
Plus not all will be able to be increased as some OEM ones may be fixed to one length
Only way to find out is open them up...the spacer will be in the uppers of the left leg
Thanks folks. They are in need of a service so may send em away and ask TFT to do it.
