Roadbike accidents ...
[Closed] Roadbike accidents caused by close-clearance frames?
As a body of experienced riders, have any of you come across any incidents where a stone or foreign body has become lodged under the forks of a low-clearance racebike?
Or where an object has caused an accident by being flipped up by a tyre and stopping the wheel? Is this sort of thing an occasional occurance, or too freakish to worry about?
This relates to a new road mudguard we are developing.
Posted : 07/07/2009 8:27 am
There was someone one here (old forum pre 'incident') who fitted some SKS guards and didn't use the safety dohdahs on the front, so the guard was properly fixed to the crown & bottom of fork. The guard caught and concertinered (sp?) between the crown & tyre resulting in supermanning over the bars and breaking his forks.
Posted : 07/07/2009 8:33 am
Ouch!
Posted : 07/07/2009 8:37 am
/Waves!
I'd err more on the freakish rather than occassional occurance. As to whether it's worth worrying about, only if you want to 🙂
Posted : 07/07/2009 8:42 am
This used to come up quite a lot on the CTC website IIRC. Old boys + old bkes + old style mudguards without a safety release jobby on the stays for front mudguard. I think there was a death.
Posted : 07/07/2009 8:47 am
I did have an incident years ago where a cr@ppy mudguard broke free of the fork crown bracket and rotated with the wheel before jamming the front wheel under the crown and sending me over the bars, still got the scars 20 years later!
Posted : 07/07/2009 8:52 am
It's worth worrying about if you manufacture mudguards!
I have a new design, and don't want to be responsible for anyone's faceplant.
I have built a safety feature into the 'guards, but I worry about situations like in your pics above. Would you hold the manufacturer responsible in the above scenario? Should he have made breakaway stays? And what if the stays entered the wheel after breaking away, and caused the accident anyway?
Posted : 07/07/2009 8:54 am
I know you don't want to copy SKS, but the way their break away is designed I don't think the stays would get stuck in the spokes after breaking away from the lower mount. Something stuck between tyre and guard would force the guard away from the tyre and so the stays would be going away from the fork, which is where they'd need to get stuck to send you over the bars.
Posted : 07/07/2009 9:05 am
I think you need to look into the relevant standards and laws, but I'd imagine if you've taken all reasonable care to ensure that the guard doesn't cause an accident, you would be OK. If you ignored the fact that breakaway stays have been developed by other manufacturers to address a specific potentially dangerous problem, you'd be ****ed if someone got injured by it.
I've never heard of an instance where the wheel has been stopped just by something lodged between the tyre and fork with no mudguard crumpling. I would imagine that the tyre would deform sufficiently to allow it to pass through without throwing off the rider.
Posted : 07/07/2009 9:06 am
I'm amazed you actually need stays. Infact I'd put money on the Crud one not having them.
Also a radical new profile that does things involving surface tension to deflect spray rather than just a big gutter?
Posted : 07/07/2009 9:12 am
Many years ago I had an old bike with metal mud guards. Going down a long hill the guard somehow rotated round to get between the wheel and the road. The front brake wasn't much cop on this bike (may well have been a rod pull brake) so I ended up flying down the hill with the back end of the bike sweeping wildly from side to side until the road flattened out.
Posted : 07/07/2009 9:17 am
 Nico
What you need is a design that doesn't go between the crown and wheel.
Posted : 07/07/2009 9:18 am
If I could figure out how to, I'd put a pic on the site for a singletrac exclusive. Brant's ideas above were all considered, but we have come up with a unique design for a full mudguard set that fits any racebike with more than 4mm clearance under the brake area. Stays yes, but no coathangers involved. weighs 200grams the pair, no metal parts. I just don't want to be responsible for any nasty accidents, so any anecdotal incidents will help us understand the dilemma.
BTW, it DOES go between crown and tyre, to give full protection. And this is where potential problems may occure. If I sell 100,000 sets, and each rider only does 1,000 miles, then there will be problems. I still don't know wether to go ahead with this project.
Posted : 07/07/2009 9:25 am
how about a two pice setup? that way anythign that would normaly clear the fork, will clear the fork?
I'm more worried about sticks in my spokes and rocks getting jammed in the chainstays on mountainbike rides.
Posted : 07/07/2009 9:28 am
Are you a limited company yet 😉
Posted : 07/07/2009 9:30 am
I'd be taking legal advice rather than asking on a forum!
There are no legal requirements for aftermarket mudguard manufacturers. You just have to research and make value judgments.
Being LTD is no longer a protection against prosecution or financial claims. I am not LTD, as I could not face the extra paperwork.
Posted : 07/07/2009 9:32 am
My boss had a nasty accident a few years back by something jamming between his mudguard and tyre.
I run sks guards on my pompino without the safety stays on the front (as I'm using them on the rear to aid wheel removal) and have them set very close to the tyre. No incidents yet but I guess I should really get hold of some of a couple more safety stay thingies.
Posted : 07/07/2009 9:35 am
I just had a look in CEN 14766
It states
4.10.2 Wheel/tyre assembly – clearance
Alignment of the wheel/tyre assembly in a bicycle shall allow not less than[b] 6 mm[/b] clearance between the tyre and any frame or fork element or a mudguard and its attachment bolts."
And also:-
4.12 Mudguards
4.12.1 Requirement
When tested by the method described in the two-stage tests in 4.12.2 and 4.12.3, the mudguard shall not prevent rotation of the wheel nor shall obstruct the steering.
4.12.2 Stage 1: Test method – tangential obstruction
Insert a 12 mm diameter steel rod between the spokes, in contact with the rim and below the mudguard stays as shown in Figure 40, and rotate the wheel to apply a tangentially-upward force of 160 N, against the mudguard stays and maintain this force for 1 min.
Remove the rod and determine whether or not the wheel is free to rotate and whether or not any damage to the mudguard adversely affects the steering.
4.12.3 Stage 2: Test method – radial force
Press the mudguard 20 mm from its free end with a 20-mm diameter, flat-ended tool radially towards the tyre with a force of 80 N as shown in Figure 41.
Figure 41 — Mudguard – radial force test
Whilst the force is maintained, rotate the wheel manually in the direction of forward movement of the bicycle and determine whether or not the wheel is free to rotate, and whether or not any damage to the mudguard adversely affects the steering.
But you probably knew this 😉
Posted : 07/07/2009 9:39 am
flint catcher to remove stones before they get caught in mudguard?
Posted : 07/07/2009 9:40 am
simon you got a photo of that? i can;t work out how to set up the rear guards on my pomp.
Posted : 07/07/2009 9:41 am
I run full length sks gaurds on the commuter and had a problem with one once...
I was riding along towards a junction and as i slowed and turned my foot caught the mudgaurd (and i only have a teeny amount of toe overlap on this bike). The mud gaurd edge then caught in a tread on the tyre and proceeded to concertina up into the fork (just like ian munro's pic), thankfully i was going slow so it just stopped me without incident. One thing i was concerned about was the 'release clips' only popped out once it folded right up, so not stopping the accident.
I put it down to my gaurds being too far from the tyre (id set them with room to run cross tyres so i didnt have to fiddle if i wanted to go offroad) so there was space for it to fold up and not force the stay out of the palstic clip. I now run the gaurd nice and close to the tyre so that if it did fold it would deffinatley pop the saftey clips, it does mean i occasionally hear grit etc. hitting the gaurd but its a lot safer now.
And to answer the original post, ive run road bikes with some VERY tight clearances and although you can get grit scraping the underside of the crown youd have to be VERY VERY unlucky for the tyre to pick up a piece big enough to actually stop your tyre, especially at speed.
Rich.
Brant, doesn't that all apply just to OEM?
I have been advised there are no requirements on aftermarket mudguards, as the onus is on the fitter.
Rich above, you are asking for trouble offroading with full mudguards!
Posted : 07/07/2009 9:47 am
[i]If I could figure out how to, I'd put a pic on the site for a singletrac exclusive[/i]
What is there to figure out? Publicly hosted pic, use the IMG buttons above the "post" box to enter the location of the pic (usually ends in .jpg)
Would be very interested to see this as never considered mudguards could fit on my roadbike.
Posted : 07/07/2009 9:48 am
You can take that opinion, and I'm sure you're correct.
There are industry people taking similar views about steel frames at the moment.
CEN 14766 isn't law in the UK.
HOWEVER - it is the most stringent test standard around, and if you want to carry on getting sleep at night and if ever gets to court, you can stand up and say "well, my XXX exceeds the best standard around by a factor of Y".
Posted : 07/07/2009 9:50 am
Next week I will teach your granny how to suck eggs 😉
Posted : 07/07/2009 9:51 am
Let me email some pics over to you Brant...I havent got yr email, but do you have mine?
Posted : 07/07/2009 9:53 am
[i]I run sks guards on my pompino without the safety stays on the front (as I'm using them on the rear to aid wheel removal) and have them set very close to the tyre. No incidents yet but I guess I should really get hold of some of a couple more safety stay thingies. [/i]
Yep, that's why I had no safeties on the front too.
I have now 🙂
Posted : 07/07/2009 9:57 am
I've done the mudguard onto close clearance frames thing for a number of years now, using the old Bluemels plastic guards, and fixing them with zipties at the fork end and under the crown. As noted, you need to set them so the guard is very close to the tyre, and put up with a bit of grit rubbing when it's wet.
One thing I would suggest is that you test the guard in temps at or below freezing; one ride was spoiled when I clipped the front mudguard with my foot and in temps of about -1, it snapped off half way up. There also seems to be a set length for guards; too short! This leads to wet feet, so a longer guard would be nice.
For frame fixing, I'd also take into account the idea that you may see people using them on carbon frames, so some proper frame protection to avoid rub marks is important in either the instructions or the package.
Keep them narrow too; 23c tyres don't need a huge gutter style thing.
Posted : 07/07/2009 10:06 am
Can't you just spend some time making a working QR for the raceguard? Mines in the bin after one use as the metal bolt just turns in the plastic housing (funny how that would happen... :p ). I've not found one decent QR mud guard (Topeak Defender too difficult to get tight enough to stop it moving, Cycraguard I'm currently using isn't exactly QR in that you need to take the post out). I can't believe it would take much to do a decent aluminium QR (hinged clamp or something), if it worked I'm sure people would pay a premium over the cheap plastic affairs out there.
As for road bike mudguard incidents, not had one myself using SKS raceblades . Happy enough with the design of the front raceblade TBH but if someone could do a decent full length rear that was stable without needing eyelets I'd be interested.
Posted : 07/07/2009 10:09 am
As Brant says, it's not law but it is best practice. Due diligence by following best practice should mitigate any legal problems under H&S legislation where you usually have to prove you are innocent.
Posted : 07/07/2009 10:10 am
Have a look at some road bike mudguards made by Giant for their Defy road bikes. They are very close clearance, and have a cutaway around the crown and rear brake as there isn't enough clearance for the guard to fit.
They fit really well on my road bike, and I've not had any issues with debris being caught (but I haven't had any issues like that without mudguards either)
Posted : 07/07/2009 10:12 am
[img] http://www.sourimage.com/show-image.php?id=aa44c1b78ccc573b23a5d96e13d99699 [/img]
Posted : 07/07/2009 10:14 am
I don't think H&S law is relevant - it's product liability he needs to look at.
How do you know they wouldn't have stopped you going over the bars?
Posted : 07/07/2009 10:15 am
Just found this...
[url= http://farm2.static.flickr.com/1041/1351102434_5f430577be_o.jp g" target="_blank">http://farm2.static.flickr.com/1041/1351102434_5f430577be_o.jp g"/> [/img][/url]
Not a great pic. If I can be bothered I'll take a better one for you.
I know, and I'm sure I said I'd fit some after your little incident 🙂
Posted : 07/07/2009 10:17 am
Best practice. Due Diligence. I remember. I'm not terribly good at big words, but TSO's and court cases scare me 🙂
Posted : 07/07/2009 10:19 am
I quite like the look of it, but it's not long enough, and I'm sceptical that it's wide enough. It looks infinitely better than a race-guard, but that isn't saying much.
As to the original question, I wouldn't use a guard without breakaway fixings, so suing you when I broke my neck would not be an issue. But there is [i]no way[/i] you can ignore a known risk of a high speed front wheel-jam being caused in not-especially-freak circumstances and expect people to slate someone's widow if she does sue you. 🙂
They should pop as soon as the gaurd tried to fold under itself (they would have if id set it up properly like i have now, ie. close to the tyre) but I was stopped by that point 😆 as the folded up gaurd had the wheel locked up nice and solid, just like the pic above, just not with a bent fork. I meant to say incident not accident anyway as i 'didnt come-a-cropper'.
Posted : 07/07/2009 10:22 am
the salmon mudguards from the salmon shop in france, not the ones that used to be sold by wiggle are supposed to be the bees knees but expensive:
http://www.cyclesdsalmon.com/gardebouesalmon2008+.htm
Also I've seen lots of audax boys who have moved the bracket for attaching the stays to the guard itself outside of the mudguard (they are typically mounted inside the channel of the mudguard. They say it reduces a lot of spray. Oh and all the mudguards I've seen really need flaps at the bottom front and rear to be really effective. Most are just too short.
Posted : 07/07/2009 10:26 am
Yeah, see, I've now seen the picture and that's way too short. Would be absolutely useless in a club ride situation where you need to prevent spray into the riders eyes behind. In the photo the guard, or a additional flap would need to extend to about the top of the first course of masonry. Also It's just going to dump rubbish onto the chainset. The front would need to be sufficiently long to avoid doing this too. Full length mudguards.
Posted : 07/07/2009 10:31 am
Dunno if the pic will work, but it's Hamish Haynes with his '6 hours in the winter' 'guards...
Posted : 07/07/2009 10:35 am
I'd be prepared to try it out for you MrCrud 🙂 Its long enough for me (I commute alone!).
Posted : 07/07/2009 10:44 am
Yeah have to agree that is too short for a rear guard. It will keep your ass dry (but then a shorter raceblade does to) but it won't do anything for someone riding behind you which is a big factor for a lot of roadies. As Mugsys said it needs to extend down to the first mortar line in the pic to stop spray going backwards.
Posted : 07/07/2009 10:45 am
I've had something stick under an SKS mudguard and the quick release stays quick release. It meant the wheel suddenly slowed down and I sort of ground to a halt - like if the brake suddenly stuck half on, but no over the bar worries. It turned out to be one of those snap on plastic wrist bracelet things - it had somehow snapped onto my tyre. Removing it and putting the mudguard back in the clips everything was fine again.
Joe
Posted : 07/07/2009 10:47 am
I've had them close enough that eventually the grit rubbing wore through the rivet. My main worry was that even with safety clips the clearance wouldn't have let a folded mudguard through so could've jammed...
But that's probably not got much to do with the new mystery product.
Posted : 07/07/2009 10:50 am
They look like a reasonable alternative to race-blades, but it's nice to see many stating that "proper" mudguardds are essential for group riding!
Posted : 07/07/2009 10:52 am
This is how i mount my rear guard on the commuter (pompino), prob just as much faff as using plastic safety clips on the rear but this way my mudguard is always in the right place for the wheel position 😀 (well apart from the bit which is bolted to the frame obviously)
Pompy Mudguard Mount
Posted : 07/07/2009 10:56 am
I have an idea for a guard that would be more than light enough, would not have things jam in it if they went up and would weigh bugger all. It's a little unconventional though.
But having said that, I've ridden over obstacles that have on more than one occasion jammed in my forks, and thats on an MTB with sus forks!
Posted : 07/07/2009 10:58 am
 Duc
I've always thought a "flint catcher" would be a very good idea based on the amount of sharp stones and road debris my winter tyres pick up due to their soft compound. If designed correctly it could also spring the safety stays earlier.
Posted : 07/07/2009 11:00 am
I've got some flint catchers in my box. Must work out how to get them fixed...
Old-skool roadieness. 🙂
Posted : 07/07/2009 11:03 am
Oh yeah, my front guard is sort of bent to get through, because of limited clearance, and the safety stays still worked, so I guess I'm the lucky one.
Joe
Posted : 07/07/2009 11:05 am
 IA
I've had a front guard get something caught under it, which jammed the wheel (on a descent :-O) till the stays popped out, but then the bracket had snapped by this point and the whole guard rotated forward and jammed again. I shat bricks, but came to a safe halt cos of the extra stopping time the safety stays gave me. I think a proper safety release is essential, and I think it's not just a freak occurrence, it can and will happen.
Posted : 07/07/2009 11:13 am
Do flint catchers actually rub the tyre? Are they spring-loaded?
Posted : 07/07/2009 11:14 am
Flintcatchers used to hover above the tyre as close as poss. If they touch they wear out in a few rides. This was in the '60s.
Thanks IA above, I think you have summed it up nicely for me.
Posted : 07/07/2009 11:18 am
Ah. I wondered if the design of a flint catcher could be modified to 'scrape' the water/road grime off a road tyre with a cowl that diverts the scraped water away.I guess it would have to be mounted fairly low, well away from the brake arch and be made of extremely hard material to be of any use.....
Posted : 07/07/2009 11:25 am
*gets paranoid*
I'm pretty sure the full guards on my cxommuter don't have any plastic safety clips or anything, they're just bolted straight on.
How do conventional safety clips work? I might try to bodge some up if its not going to increase the risk of failure in the first instance.
Posted : 07/07/2009 12:32 pm
ADH - they are plastic clips that you push the "fork" end of the stays into, and then bolt to the fork end. It does take a reasonable amount of force to pull the stays out. I'd have thought alot of lbs would have some kicking around.
Posted : 07/07/2009 12:37 pm
ADH you can buy the SKS ones from St John Street Cycles. You push in the loop that the bolt goes through basically, so you will probably be able to retrofit very easily.
Posted : 07/07/2009 12:48 pm
Cool, I'll go pilfer some.
Mate rolled off a ramped kerb from a deadstop behind me last year, flicked a twig into his front wheel and stopped the bike dead. Think the mudgaurd stays acually kept the branch nicely square in the spokes long enough to hit the forks - face plant, broken arm/elbow from about 2mph top speed. The safety things didn't pop out in time. Concertinered the front guard.
That was on an old curly Hetchins frame so massive space under fork crown.
But I'd certainly buy that rear guard. If you can get a front one working I'd have one of those too.
Oh, and a wide 29er ones too for the commuter - add me to that list too!
Posted : 07/07/2009 1:15 pm
Thanx for the response everybody... I have done some major mods to the design thisafternoon, and think I have overcome all probs.
This probably reads like a marketing exercise, but I have got a lot from this forum and really appreciate the input.
Posted : 07/07/2009 1:39 pm
Bring back the originals!
Ive still got a pair like these ^^^ but im missing one of the rear stays 😥
Posted : 07/07/2009 2:20 pm
