Goodridge Brake Hos...
[Closed] Goodridge Brake Hose Shortening..
[#690096]
Hope Mono Minis connected via Goodridge hoses.
Any tips before I go ahead and shorten? They seem to use different fittings compared with hope and every other manufacturer of brakes.
Ta, J
Posted : 07/07/2009 8:38 am
If they are using std goodridge fittings, then they should be re-useable.
If they are std fittings then its probably easiest to remove them before cutting. The caliper end is prob the best end to cut. The caliper fitting should just unscrew from the hose / metal sleeve and then the metal sleeve should just pull off.
Check out the goodridge website for a guide to show how it goes together.
Use a pair of good quality cable cutters and cut the hoses to the required length and don't forget to bleed them after you've finished. DOT 4 or 5 fluid remember!
Posted : 07/07/2009 8:49 am
