Road hydraulic disc...
[Closed] Road hydraulic discs
[#3749272]
http://www.cyclingnews.com/news/tech-colnago-launch-c59-disc
Colnago are putting their weight behind it as apparently are Shimano who incidentally are a big UCI sponsor...
Something to note - the Formula hydraulic discs - with their own brake/shift levers - maybe the first ones of the rumoured brake/shifters that will be compatible with Di2 but not Shimano...
Posted : 07/03/2012 1:13 pm
It'll never catch on. Canti's are good enough. Proper racers go faster with poor brakes. Having better brakes is no benefit.
Posted : 07/03/2012 1:15 pm
 cp
very neat.
Wonder if deep section full carbon rims can become lighter now they don't have to support a braking surface and associated heat generation.
Posted : 07/03/2012 1:17 pm
 Rik
Cynic-al - that's a road bike.....not cross
Wow - very cool.
Goes off to research again. Must say I prefer SRAMs hyrdo brake/cable gear solution rather than di2 - but would prefer shimano hydros/Sti's over Avid/double tap.
Waits for big shimano decision. If you look at the new Shimano Sora Sti design it looks like they have made the hood bigger maybe a rolling change to eventually be able to fit in a hydro master cyclinder....
Posted : 07/03/2012 1:32 pm
Dammit. First I wanted a road bike for a faster commute, then I wanted a SS road bike for no maintenance probs (and iron legs), then I wanted a 'cross bike for the better brakes, then I wanted a steel cross bike as I like the narrow tubes, then I wanted a croix de fer for steel/cross/disc lovliness, now I want hydraulic discs on a super fast looking road bike.
I want never gets, it just gets more demanding!
Posted : 07/03/2012 1:43 pm
Ah, the joys of threading hydraulic hose through a frame then having to bleed afterwards!
Posted : 07/03/2012 1:56 pm
 flip
Merde..
Posted : 07/03/2012 1:58 pm
That hose routing doesn't look too bad. At least there's a plastic insert so you can hook the hose end out as you feed it through. Having seen some mind-bogglingly stupid solutions to internal brake and gear cables, I'd welcome hydro + Di2.
As CP says, there'll be a proper leap forward in road wheel technology now. Overall weights won't drop, but I'd expect to see some fancy-pants rim-tyre systems with supposedly 20% more everything!
Posted : 07/03/2012 2:16 pm
*looks closely*
Is that the old (3 bolts) formula mount re-appearing?
Could formula be trying to cash in by getting their brakes as the standard?
[edited] it's not
Posted : 07/03/2012 2:22 pm
 JoB
going to be popular among those that race sportives i'd wager
Posted : 07/03/2012 2:35 pm
LOL @ JoB - but sportives are races! 😉
Rik, I know, just poking fun at the usual crap posted re. skinny tyres and discs.
Posted : 07/03/2012 2:57 pm
Am still torn on this.
Love the grey paint job, though.
Posted : 07/03/2012 3:00 pm
I'm in no rush for disk's on a road bike, but i'll give them a go quite happily. But that Colnago has made me pitch a trouser tent!
Posted : 07/03/2012 3:05 pm
That looks fantastic (and I'm not a fan of Colnago at all).
At least this time they've managed to stop themselves throwing a million colours of garish paint at it. The discs look neat, full internal cable routing, no calipers spoiling the clean lines of the frame and a mere 200g weight gain over cable brakes.
Someone find TJ - I'm sure he'll think it's massively unnecessary... 😉
Posted : 07/03/2012 3:06 pm
IIRC this is one topic he does not hold strong opinions on.
Posted : 07/03/2012 3:08 pm
I think that looks rather ace, but then I'm not a roadie.
Quite in favour of disc brakes on all bikes as they have massive advantages and are a very simple system of few moving parts.
Posted : 07/03/2012 3:13 pm
 Rik
I can't find any futher info on the formula brakes as yet.....
Posted : 07/03/2012 3:15 pm
 Solo
My next build willbe a hydro braked road bike.
For me ?, cable and rim brakes are deader than corduroy.
Posted : 07/03/2012 3:45 pm
I like corduroy, rim brakes and cables.
Posted : 07/03/2012 3:47 pm
 Solo
[i]I can't find any futher info on the formula brakes as yet..... [/i]
Heres a fact for you.
They wont be [s]cheap[/s] affordable !.
Posted : 07/03/2012 3:48 pm
 Rik
Wouldn't buy formula brakes .
I'm waiting for a Ultegra level hydro brake, cable gear Sti's myself. Available in both 2x10 and 3x10 systems like they are now.
Posted : 07/03/2012 3:54 pm
[s]as they[/s] [b]helmets[/b] have massive advantages and are a very simple system of few moving parts.
*lights touch paper and leggs it*
Posted : 07/03/2012 4:35 pm
See, this wouldn't be a problem with the current 15 lb/6.8 kg weight limit as they'd just use a lighter rim or take some ballast out of the frame. But the UCI's talking about dropping the weight limit which would (presumably) lead to a race to the lowest weight where 400g (I'm guessing it means 200g per brake seeing as a caliper now is ~100g) would be very significant.
Posted : 07/03/2012 4:39 pm
Yeah but the UCI is unlikely to make the new weight limit anything that can't fairly easily be achieved with off the shelf parts so it's unlikely that anyone will struggle to hit the new limit even with 200g extra.
Posted : 07/03/2012 4:45 pm
in a related conversation, Brant sent me this link. May be of interest to some in here:
http://www.bikerumor.com/2012/02/14/road-bike-disc-brakes-are-coming-but-will-they-work/
Posted : 07/03/2012 4:58 pm
If only we could dig up the old threads where there were folks claiming that a well set up pair of V brakes were as good as discs, we could simply read that thread instead
Posted : 07/03/2012 5:00 pm
Yeah, read that article on the failed brakes on a road bike. Interesting...
but... BB7s have been in use on road bikes for a while and it's clearly not the case that discs fundamentally fail. Add in the silly light rotors used and the author's own admission that it wasn't clear cut.
It clearly does show though that you need to consider heat dissapation.
Posted : 07/03/2012 5:16 pm
Hope are developing a cable to hyd brake system for CX.
[url= http://www.hopetech.com/page.aspx?itemID=SPG342 ]HOPE CABLE / HYD CX BRAKE[/url]
Wont be long before the levers follow from some other manufactures.
Posted : 07/03/2012 5:24 pm
 Solo
[i]I'm waiting for a Ultegra level hydro brake, cable gear Sti's myself. Available in both 2x10 and 3x10 systems like they are now. [/i]
Yeap !, me too.
Posted : 07/03/2012 5:27 pm
that bikerumour article is a joke and should be pulled IMO, gives bike journos a bad name.
Posted : 07/03/2012 5:28 pm
 RV
Seen some new Shimano prototype brakes that make an improvement over the existing durarace brakes and look very different. All compatible with the Di2 system. Not due for release for a while yet.
Posted : 07/03/2012 5:56 pm
the journo stuff isnt worth reading, but the stuff from the manufacturers is more informative.
Posted : 07/03/2012 5:58 pm
The problem is that it's very easy to scoff at him and say "what an idiot, not knowing how to brake" - but is everyone who buys a road bike going to get a free lesson on how to use the brakes? He admits there are issues with the choice of equipment, but we can't expect everyone to know how to use their new 'far superior' brakes.
People drag the brakes. They have always been able to do this with cable brakes. They will expect hydro dicss to be far better (just look at half the opinions on here), and will not expect to need to change their technique. L'etape will be utter carnage!
I can't see rims getting much lighter. the need for a braking surface on a tub rim is fairly arbitrary seeing as they're basically a square profile anyway. Clinchers are heavy because you need to reinforce the bead for the tyres a fair bit. This doesn't change because you take out the need for a braking surface.
Posted : 07/03/2012 6:05 pm
With Shimano rolling Di2 out to groups like Alfine I can't see them bothering to combine mechanical gears and hydro discs. I think your options will be Di2+hydro/Di2+mechanical/mechanical+mechanical. Is it not in that artical (cba reading it again, it may have been somewhere else I read it) that Shimano say they are bringing out a new mechanical disc?
 cp
An aluminium braking surface wears down to a minimum point, so there's some weight gone - just make an aluminium rim the otherwise minimum thickness.
I've only ever seen carbon clinchers with an aluminium braking surface so that heat is dealt with better and the clincher doesn't pop off when the resin softens... you don't have heat build up there, so would we see all-carbon clinchers? (maybe these already exist, but I've not seen them).
Posted : 07/03/2012 6:26 pm
 cp
OK, I've googled an found full carbon clinchers already exist. I can imagine though that even these can be made quite a bot lighter with discs as the resin wont soften with brake temperature build up, so you don't need extra meat there to support the tyre when warm.
Posted : 07/03/2012 6:29 pm
njee20 - Member
I think we can expect a journo to try and find out, and when things go wrong, not turn his own pathetic story into an article.
Posted : 07/03/2012 6:39 pm
Brilliant. The first really decent road bike with discs*. I'm very tempted. Anyone know when this is available?
*Volagi have one but it's a bit of a munter.
Posted : 07/03/2012 7:37 pm
 juan
Not with formula new system (as in the new meta fame)
Posted : 07/03/2012 7:42 pm
 mrmo
whether people want discs is completely irrelevant, they are going to arrive on road bikes. Personnally i don't really see many benefits, yes there are some, but not enough to make me rush out and buy them. The next road bike i get will probably have discs as i suspect when i come to buy a new road bike that will be all that is available.
Posted : 07/03/2012 7:43 pm
It already is. I've ridden two editions, and both have had great big pile ups on the first descent..!
Posted : 07/03/2012 8:11 pm
Why is it still in primer?
Posted : 07/03/2012 9:06 pm
heat dissipation?
/coff
carbon discs
Posted : 07/03/2012 9:53 pm
Having had a quick skim through that I would say it is a significant flaw that the brakes faded because (by his own admission) he was dragging them.
There will be many people who do this, not everyone is a riding god worthy of a pro tour team place like people on this forum. There are plenty of situations where I've thought it necessary to drag the brakes.
Following slower vehicles and riders.
Bad weather/poor visibility
Nerves
Something else faulty on the bike (see nerves)
Poor road conditions (broken up, muddy, gravel)
If the hill is steep enough then you'll need to brake pretty much continuously to keep your speed down, and this is in the UK, not the alps etc.
Posted : 07/03/2012 10:51 pm
Page 1 / 4
