Reverb Virgin - wha...
[Closed] Reverb Virgin - what are all the bits in me box?!
So my lovely Reverb arrived (£165 from bike discount.de , full retail version) and there are lots of er bits that I'm not sure what to do with!
A plastic hose guide? Where does that go?
An anodised aluminium bit that looks like it's somehow related to the seat clamp?
A red rubber cover bit (like a cable end cap)?
Little double - C shaped plastic bits with the C's at 90 degrees to each other ?
Thanks , I know I'm stoopid :-/
Posted : 11/03/2015 10:58 am
A plastic hose guide? Where does that go? [b]On any exposed bottom part of your seat post or frames seat tube to guide the hose.[/b]
An anodised aluminium bit that looks like it's somehow related to the seat clamp? [b]Sounds like the black filler bit that fills in the gap in the remote clamp[/b]
A red rubber cover bit (like a cable end cap)? [b]Stops crap getting into the hose and helps prevent oil leaking out if you have to disconnect the remote to feed the hose through bits.[/b]
Little double - C shaped plastic bits with the C's at 90 degrees to each other ? [b]No idea, could they be for clipping the hose to a brake hose or gear cable?[/b]
Posted : 11/03/2015 11:04 am
hose guide - goes around the top of seat tube with a zip tie, guides the hose during compression
Aluminium bit - emergency collar - pop in camelbak in case post mechanism fails and you need to clamp it up (actually called an endure collar I think)
red bit - dunno
dounble c bits - hose clips so you can clip together the reverb hose to a brake hose, though the routing, like along seat tube, near bars etc.
Posted : 11/03/2015 11:05 am
Cheers! I think the double C bits could we'll be to attach the hose to another in the absence of frame guides.
I can't quite figure out how the hose guide fits?! The manual doesn't mention any of these bits!
Posted : 11/03/2015 11:10 am
iainc - Member
They call that the "enduro collar", because enduro
It's for limiting the drop - you can clamp it on the upper part so the seat only drops to a certain height.
Posted : 11/03/2015 11:14 am
.. And there's spare hex bolt, smaller than those used in the seat clamp and lever clamp?
I assumed the silver seatclamp just replaced my old QR?!
Posted : 11/03/2015 11:16 am
you can see the hose guide etc on this pic
[img] ?oh=6e18d28eb9be0b157516c839d2e68357&oe=5570137A&__gda__=1433833203_3e2e6c43b107fcb62d581ca5facd07a7[/img]
red bit - That holds the MMX bolt (the loose hex bolt you mention) in the clamp before fitting - its just packaging.... bin the red bit.
Posted : 11/03/2015 12:20 pm
