Reverb stuck down :...
[Closed] Reverb stuck down 🙁
5 Users
Bought a reverb from the classifieds a couple of days back minus the remote with a view to swapping the remote from my saggy reverb, went to fit it today, swapped the remote over, gave it a bleed and went to function it, it went down and stayed down, gutted. I re bled it several times, no joy. The only way I can get the post extended is to remove the air and manually pull it up, bled again several times, added 250psi, sucks it back down again, another couple of bleeds and still the same 🙁
I've given up for now and refitted the remote to my saggy reverb, does anybody have any suggestions for sorting this that don't involve a full strip down? Don't want to return it for a refund unless I have to but I don't want to do a full strip down on something I've bought in perfect working order (I've no doubt it was but isn't now).
Cheers in advance,
Steve
Posted : 09/11/2014 5:52 pm
It would be on it's way back if that where me.
Posted : 09/11/2014 5:58 pm
Replied yo your mail Steve
Rob - post was perfect but thanks for you comments...
Only sold as I changed frame and fitted a stealth.
Posted : 09/11/2014 6:26 pm
I had this problem too. Try this, it worked for me after a lot of swearing. Pressurise the seatpost - it sucks the saddle down as you say. Then press and hold the trigger in while pulling the saddle up.
Posted : 09/11/2014 6:30 pm
booktownman - cheers for that, I'll give it a bash tomorrow.
Posted : 09/11/2014 6:43 pm
Bump for the Monday morning crowd before I get busy in the man cave!
Posted : 10/11/2014 9:04 am
Hope your sorted by now but just seen this....
http://singletrackworld.com/forum/topic/how-do-i-extend-my-reverb-without-the-remote
Could take a couple of bleeds
Posted : 11/11/2014 8:55 pm
Cheers Mark, I ended up running out of time this afternoon after squeezing a cheeky ride in so it remains on my jobs to do list!
Posted : 11/11/2014 9:09 pm
Dont forget to turn the return speed adjuster fully positive as well.. Fully slow is very slow indeed...
Posted : 11/11/2014 9:20 pm
Had another mess around tonight, no joy 🙁 any other suggestions?
Posted : 12/11/2014 9:33 pm
Hhhmmm
http://m.youtube.com/watch?v=MsRlj_JJ8t0
Is this the way you tried it?
Posted : 12/11/2014 10:23 pm
Did u mention in an email that if you let the air out you can extend it up?
What about doing that, bleeding it then adding air?
I'm stumped as it was 100%
I feel bad that you having hassle.
Have you a lbs could try a bleed or something?
As I said, all I done with the stealth post was put my lever on and bled the lever..
Posted : 12/11/2014 10:44 pm
Any luck?
Posted : 14/11/2014 12:06 pm
Thread update, I managed to get some reverb viagra and got it up 🙂
After loads of bleeding, air in, air out, pulling up on the post whilst pushing the button, putting a different hose and barbs on, more bleeding and still the post remained stuck down when it was pressurised with air, without pressure in the post you could still pull it up by hand but as soon as you put air in it sucked back down. As a last ditch idea I decided to discharge it of air, pull up by hand then hold the remote button in whilst pumping air back in (a true 3 handed job!) and finally it stayed up and now works as advertised. What a mare that was. Cheers to kendo954 for keeping an active interest in making sure I got it sorted. Hope this helps someone else in the future as google proved fruitless for me.
Posted : 14/11/2014 7:09 pm
As per email ...... Glad your up and running 🙂
Posted : 14/11/2014 7:14 pm
