Reverb button repla...
[Closed] Reverb button replacement
My Google-fu is evidently weak today.
Is there anywhere that sells a replacement Reverb button (just the black alloy end piece) without having to buy the whole kit for £40?
If not, anyone with a 3d printer fancy having a crack? 😉
Posted : 26/10/2015 3:40 pm
If only you knew some local engineers 😉
Posted : 26/10/2015 3:44 pm
And preferably made of steel rather than the die cast cheese they make their's out of.
Had to replace the whole lever as I'd also scored the bore, cost me 80 quid, don't think I'll ever get over it.
Posted : 26/10/2015 3:55 pm
Swap you for a website Steve? 😉
Don't get me started, already bent the shaft and replaced with a stronger aftermarket one. Pretty sure that gouged the internals as every now and again it needs a top up of fluid to get it back to life.
Posted : 26/10/2015 4:02 pm
