Replacing an air ca...
[Closed] Replacing an air can on an RP23
6 Users
Managed to crack the housing on the aircan on my RP23. I am currently trying to source another one second hand (they are pricey from Fox / Mojo). I am looking for either the standard or larger air can as i beleive they will both fit.
Looking on You tube is it just a case of letting the air out, removing the shock and unscrewing the can, replacing together with new seals?!?! It is simply that easy or have I missed something?
Posted : 09/05/2011 1:05 pm
Yep pretty much. Just need to add a few drops of fluid to keep the seals sweet.
What size shock is it for? I have a little used HV 190x50 one I don't need
Posted : 09/05/2011 1:12 pm
retro83 you don't by any chance have a spare 190x50 or 190x57 air shock for sale do you.
Posted : 09/05/2011 1:20 pm
the aircans are the same size
Posted : 09/05/2011 1:22 pm
i've got an unused large aircan from my rp23 going, only removed to swap for smaller can, yours for £15 posted?
to fit it, depressurise the shock and then with a vice like hand grip unscrew, simple as that!
Posted : 09/05/2011 1:28 pm
Afraid not, just the air can.
Posted : 09/05/2011 1:34 pm
Depending on your shock eyelet bushing arrangement, you need to remove one of these too.
Posted : 09/05/2011 1:54 pm
Cheers Lummox, I will mail you directly.
Apprecaite your replies, looks like I will be servicing my shock this weekend!!
Posted : 09/05/2011 2:58 pm
