Hi All,
Following a previous post I'm still having issues with chain slip on my XT double chainrings after fitting a new chain. The replacement ring for the XT double front is about £55 which is a bit steep so was wondering if there were any similar rings from lower down the Shimano range or even other manufacturers that would do the same job.
It's a 36t ring and is standard Shimano fitting from what I can see.
Cheers,
Mart
Race Face, Middleburn, Blackspire, FSA, Stronglight all good.
SLX or Deore, though you might have to file the fitting tabs on the chainrings slightly to fit. Apparently 9 speed rings are fine, if your using 10 speed as the chains internal width are the same (lots of threads, do a search).
Okay, so I don't need to worry about whether it's a middle or designed as an outer ring then?
I got this, works fine
[url= http://www.chainreactioncycles.com/blackspire-super-pro-middle-ramped-2013/rp-prod435 ]Blackspire super pro[/url]
